Okay, so the electric coolant auxiliary heater in my car (Golf 4, 66kw ALH, manufactured in July 2000, 100,000 km) isn't working anymore. It's supposed to provide extra heating after a cold start.
The error memory is empty.
The actuator test with these two outputs for the relay works: I can hear the relay clicking, and based on the interior lighting, I suspect that electrical energy is being converted into heat.
http://kuypers.bei.t-online.de/Bild1.jpg
The bit patterns in 16-2 and 16-3 no longer change when the engine warms up.
It looks like there's a problem with the engine control unit. The rightmost bit = 1 in position 16-2 should actually be = 0.
Best regards, Gerd.
Translated on 28-09-2026, 19:51.
