Retrofit AHK for Galaxy 1999: Installation Guide
PD90
Registered VCDS User
Post28-07-2009, 20:26    Subject: Retrofit AHK for Galaxy 1999: Installation Guide Quote
Hi everyone,
I installed a fixed tow hitch on my father's 1999 Galaxy 1.9 TDI (81kW).
Everything went smoothly, and the installation of the electrical wiring was actually quite easy.
The description now states the following:
Activating the additional indicator light:
The additional indicator light for trailer operation is vehicle-side.
already available and pre-packaged.
To do this, the vehicle's own control unit or multifunction unit must be connected to a special...
V.A.G. service testers (type 5051, 1551, 1552) or with the Ford FDS 2000 test system.
The system should be parameterized according to the body/self-diagnosis guide after the installation of the electrical wiring harness.
The additional indicator light for trailer operation will then be activated.
=> I've already installed a gasoline particulate filter (GPF) on the car and unlocked it using a VAG diagnostic tool.
but how and in which vehicle system should I activate the trailer control light?
is completely beyond my knowledge...
I think it can actually only happen in combination (17), right?
Hoping for your help...
Greetings, PD90.
(who doesn't want an AHK in his G5!)
Translated on 31-08-2026, 11:49.
PD90
Post29-07-2009, 16:17    Subject: Retrofit AHK for Galaxy 1999: Installation Guide Quote
Okay, after doing some more searching on the internet, I came across the following:
=> On-board network (09), not a combination (17)
Encoding.
Add +8 to the existing value, and everything should be fine.
Let's see if this works as planned...
Greetings, PD90.
Translated on 31-08-2026, 11:51.
No new posts Aftermarket Leather Steering Wheel with Airbag Troubleshooting & Guides
No new posts Retrofitting a tow hitch on a Passat 3C, model year 2007 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts FSE Premium Retrofit for Passat, Golf, Tiguan Troubleshooting & Guides
No new posts Galaxy with 277,000 km mileage, deceased. Diesel Engine Technology
No new posts Galaxy TDI Engine Mounts Diesel Engine Technology
No new posts OBD Socket Galaxy? On-Board Diagnostics (OBD)
No new posts Galaxy AHU: Atmospheric Pressure Explained On-Board Diagnostics (OBD)
