Check TDI injectors with VCDS (Common Rail) (Solution)
Karma: +807 / -0   Thank you, like it!
Post30-10-2012, 17:16    Subject: Check TDI injectors with VCDS (Common Rail) Quote
The injectors of the 2.7L V6 TDI and 3.0L V6 TDI engines can be checked for abnormalities using the zero-quantity calibration function in VCDS.
The control durations for each calibration pressure can be found in the engine control unit within measurement blocks 72-76.
More recent 1.6/2.0/2.7/3.0 CR-TDIs make these values available, but somewhat hidden, in the extended diagnostic data blocks.
The following limits apply to 2.7/3.0 CR-TDIs, feedback on all engines and their calibration pressures is welcome.
Still to be clarified is why "ms" is displayed here for my 2.0 TDI, while "us" is shown instead. icon_question.gif
As limits, a value of -45ms can be applied to the first value in each measurement block, and a different limit applies to the second value. Value (calibration pressure) -15ms.
Larger negative values indicate wear on the respective injector, which then no longer closes properly or drips.
Larger positive values indicate carbonized injectors or clogged nozzle openings.
Ratings - Check TDI injectors with VCDS (Common Rail)
No new posts Battery Status with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Train T90 / T 91 with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Common Rail Injectors: LT 35 Refurbishment? Diesel Engine Technology
No new posts TDI with Common Rail: Explained & Benefits Diesel Engine Technology
No new posts Common Rail vs. TDI: Which is Better? Diesel Engine Technology
No new posts Common Rail Tool Set for Timing Belt Replacement Diesel Engine Technology
