1.9 TDI (AWX): Reduce Compression Ratio
Passy09
Karma: +1 / -2   Thank you, like it!
Post13-10-2009, 12:11    Subject: 1.9 TDI (AWX): Reduce Compression Ratio Quote
Good day to the tuning community.
I drive a Passat 3B, originally with the AFN engine, but it has been converted to the AWX engine.
My car's performance is starting to feel a bit underpowered; I'm looking for something with around 200 horsepower or more.
So, I was thinking about possibly installing a larger charger, something along the lines of...
GT2256V oder gar. GT2260V.
Since I've been thinking about the peak pressures involved, I wanted to ask...
"I'm wondering how I can reduce the compression on my AWX."
Are there any pistons available for that (engine/machine)? Or can you even make your own?
If I want to achieve approximately 240-250 horsepower, how low should I ideally lower the...?
Compression down?
Thank you in advance.
"MFG" is an abbreviation for "Mit freundlichen Grüßen," which means "Sincerely" or "Best regards" in English.
Passat 3B umbau auf AWX, GT17/20 Hybrid, große PDE, EMS und Sachs Performance.
205PS, 425nm Drehmoment
Translated on 08-09-2026, 17:31.
Post13-10-2009, 12:19    Subject: 1.9 TDI (AWX): Reduce Compression Ratio Quote
Translated on 08-09-2026, 17:32.
Passy09
Post13-10-2009, 12:28    Subject: 1.9 TDI (AWX): Reduce Compression Ratio Quote
I haven't really had a chance to talk to him about it yet.
They live a bit further away and don't really have the time for that right now.
But maybe you offer something like that?
Ah yes, the 216 nozzles have arrived.
Post13-10-2009, 13:15    Subject: 1.9 TDI (AWX): Reduce Compression Ratio Quote
But maybe you offer something there?
I used to, but I'm in the same situation as him: I simply don't have the time for that kind of thing, and it's totally unprofitable to produce it in such small quantities.
Translated on 08-09-2026, 17:33.
Passy09
Post13-10-2009, 13:20    Subject: 1.9 TDI (AWX): Reduce Compression Ratio Quote
Hmmm....
Can you tell me what the compression ratio needs to be for 240-250 horsepower?
Using a 3-hole ZKD (presumably a type of connector) or stacking two of them on top of each other is a rather crude and unprofessional solution.
You understood correctly.
Are there any other ways to reduce the load on the engine?
Translated on 08-09-2026, 17:34.
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts WIV reset on VW Polo 9N TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MKB 1.9Tdi Upload
No new posts Motoraussetzer 1,9Tdi 1Z Diesel Engine Technology
No new posts Passat B6 1.9 TDI: Starting Problems & Solutions Diesel Engine Technology
No new posts Burnt Piston 1.9 TDI AFN Golf 3 Diesel Engine Technology
