Front Wheel Noise Passat 3B AFN
Kradmelder
Post07-02-2003, 9:09    Subject: Front Wheel Noise Passat 3B AFN Quote
Hello everyone,
I'm an avid reader of this forum and have received a lot of helpful information. I'd like to share a quick success story. On my Passat, with 127,000 km on the odometer, I had the well-known rattling noise in the front axle when driving over bumps. After thoroughly inspecting all the steering components, struts, and tie rods, I found that the upper ball joint on the right tie rod was worn out. I only replaced that one tie rod (for €24).
'According to VAG, the rod with ball joints has been replaced with one using fixed rubber bushings and can be used without any problems. I have done this, and the clunking noises are gone.'
Is that correct regarding the replacement?
Kradmelder.
Translated on 24-09-2026, 7:44.
Michael II
Post07-02-2003, 10:50    Subject: Front Wheel Noise Passat 3B AFN Quote
That's okay.
Tschüss
Michael II
Translated on 24-09-2026, 7:45.
No new posts Audi A2 Noises: 8Z0 MJ 2002 Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0044 AMF, Creaking Noise Front Axle Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Phaeton Noise: Front Axle 3D2 Diagnosis Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Golf 4 1.8T: AGU/MSG ECU to Polo 6N WFS On-Board Diagnostics (OBD)
No new posts Aero Wiper Blades: Retrofit for VW Passat 98 Transmission, Chassis, Body & Interior
No new posts Passat Tire Wear: 3B Sedan, 98, 110 HP AFN Transmission, Chassis, Body & Interior
No new posts Differences between the 96 AFN (Golf 3) and the 98 AFN (P... Diesel Engine Technology
