Golf 3 Ventilation Control System
Maik
Post05-02-2003, 9:08    Subject: Golf 3 Ventilation Control System Quote
Hello, I just noticed that my Golf isn't blowing any heated (or fresh) air into the footwell area. All the other vents are working. Where can I find the slider that controls this?
Sure, here's the translation:
'Thank you in advance.'
Maik.
Translated on 07-10-2026, 0:17.
Michael II
Post05-02-2003, 9:47    Subject: Golf 3 Ventilation Control System Quote
Have you read the instruction manual yet?
Tschüss
Michael II
Maik
Post05-02-2003, 12:46    Subject: Golf 3 Ventilation Control System Quote
I'm not talking about the control knob in the center console. I'm referring to the slider that distributes the amount of air inside the car. Is it located behind the center console? Or is it easier to access?
Maik.
Translated on 07-10-2026, 0:18.
Post05-02-2003, 19:23    Subject: Golf 3 Ventilation Control System Quote
Maik wrote:
I'm not talking about the control knob in the center console. I meant the slider that distributes the amount of air in the car. Is it located behind the center console? Or is it easier to access there?
Hi Maik,
As far as I know, the vent valve is unfortunately located deep within the dashboard, making it difficult to reach, as I recall from a previous attempt to find it.
I believe that, starting from the passenger footwell, you can reach the dashboard with 3 to 5 hand and arm stretches... icon_confused.gif
Translated on 07-10-2026, 0:19.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 3 Speedometer with Golf 4 6-speed? No signal. Diesel Engine Technology
No new posts Golf 2 GTD/16V: Brake Caliper & Wheel Bearing Mount Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Golf 3 TDI: Install 6-Speed Golf 4 Transmission Diesel Engine Technology
No new posts Golf 3 Instrument Cluster in Golf 2 Dashboard Transmission, Chassis, Body & Interior
