Read Polo 99 (6N1) WFS pin code
Go to page: 1, 2  Next
svet
Post16-05-2010, 21:57    Subject: Read Polo 99 (6N1) WFS pin code Quote
Hello everyone,
Does anyone have an idea on how to retrieve the WFS PIN for a 1999 Polo (6N1)?
Best regards.
Svet.
Translated on 16-07-2026, 2:50.
Post16-05-2010, 22:00    Subject: Read Polo 99 (6N1) WFS pin code Quote
Depending on the type of enclosure used, here are the different methods available.
svet
Post16-05-2010, 22:11    Subject: Read Polo 99 (6N1) WFS pin code Quote
TDI-GTI-4Motion.
"First of all, thank you for the quick response. However, I have an 8-pin WFS box. Unfortunately, I can't find the test clip tool (for directly reading the NVRAM chip) anywhere online."
Translated on 16-07-2026, 2:51.
Post16-05-2010, 22:17    Subject: Read Polo 99 (6N1) WFS pin code Quote
svet wrote:
Leider finde ich den Test Clip Tool (zum direkten Auslesen des NVRAM Chips) nirgendwo im web.
Logically, as stated in the link, this option only applies to the 10-pin box.
mullemaus
Post16-05-2010, 22:34    Subject: Read Polo 99 (6N1) WFS pin code Quote
8-pol has an MCU inside. icon_wink.gif It can only be accessed using a special programmer, or K+CAN should be able to do it. icon_wink.gif
Translated on 16-07-2026, 2:52.
svet
Post16-05-2010, 22:44    Subject: Read Polo 99 (6N1) WFS pin code Quote
I don't quite understand. So, would it not work with VCDS, but only with the Clip Test Tool (a special programmer), or does it work? How can you tell if a box contains an MCU?
Post16-05-2010, 22:49    Subject: Read Polo 99 (6N1) WFS pin code Quote
No, that doesn't work with either VCDS or the Test Clip. The Test Clip only works with a 10-pin connector.
Translated on 16-07-2026, 2:53.
mullemaus
Post16-05-2010, 22:55    Subject: Read Polo 99 (6N1) WFS pin code Quote
I don't quite understand. So, would it not work with VCDS, but only with the Clip Test Tool (special programmer), or does it work? How can you tell if a box contains an MCU?
8-pin has a small square MCU inside. The 10-pin has a 24c04 - 8-pin EEPROM icon_wink.gif. I'll show you a picture.
svet
Post16-05-2010, 23:13    Subject: Read Polo 99 (6N1) WFS pin code Quote
I think I know what you mean.
http://tempsens1.hit.bg/immo10.jpg
"Nevertheless, how do I do it with the 8-pin connector?"
Translated on 16-07-2026, 2:54.
svet
Post17-05-2010, 10:53    Subject: Read Polo 99 (6N1) WFS pin code Quote
mullemaus wrote:
The 8-pole connector has an MCU inside. icon_wink.gif It can only be programmed using a special programmer, or K+CAN should be able to do it. icon_wink.gif
Are you sure that an 8-pin connector will use the K+CAN interface?
mullemaus
Post18-05-2010, 0:12    Subject: Read Polo 99 (6N1) WFS pin code Quote
8-pin connectors are considered part of the IMMO I and should work. Information provided without guarantee. I would choose a different tool for that box. icon_wink.gif
Translated on 16-07-2026, 2:55.
svet
Post18-05-2010, 13:15    Subject: Read Polo 99 (6N1) WFS pin code Quote
icon_smile.gif and this time you might mean:
http://tempsens1.hit.bg/tool.jpg
The problem is that this tool is difficult to find. Can anyone provide me with an electronic schematic?
mullemaus
Post18-05-2010, 14:19    Subject: Read Polo 99 (6N1) WFS pin code Quote
No, that is a 24Cxx tool. MCU = processor, not EEPROM like the 24Cxx icon_wink.gif.
Translated on 16-07-2026, 2:56.
svet
Post18-05-2010, 18:33    Subject: Read Polo 99 (6N1) WFS pin code Quote
How's it going? Do you have a picture? Currently, there's no way to remove the immobilizer box. Otherwise, where can I find more information on this topic?
mullemaus
Post18-05-2010, 19:20    Subject: Read Polo 99 (6N1) WFS pin code Quote
Translated on 16-07-2026, 2:57.
svet
Post19-05-2010, 8:12    Subject: Read Polo 99 (6N1) WFS pin code Quote
"...does that mean that VAG dashboards should be able to do it?"
But I think it's more likely that my device is not of the IMMO 1 type.
No new posts Polo 86c 40 kW, year 1992, 1272 ccm, AAV throttle potenti... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo Combo Instrument Cluster, 10.99-09.2001 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo combination instrument panel, 1998 to 09.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 97 Polo MKB AEE, Diagnostic error reading Gasoline Engine Technology
No new posts Polo 2F 3F Engine: Read/Log Lambda Values On-Board Diagnostics (OBD)
No new posts How to Read: A Beginner's Guide On-Board Diagnostics (OBD)
No new posts Read Email: Extracting Messages Easily On-Board Diagnostics (OBD)
