winnie4get Blaumann
![Avatar-winnie4get]()
Joined: 03/02/2008 Posts: 14 Karma: +1 / -0 Location: Stade
11-05-2009, 21:00 Subject: 1.9 TDI Head on 2.0 TDI Engine Conversion |
Hello, I would like to know if the cylinder head from a 1.9 TDI ATD engine will fit on the block of a 2.0 TDI BMM engine, including all related components such as mounting brackets and engine mounts, etc.
Best regards, Winnie.
Translated on 26-07-2026, 10:46.
Tagessuppe Profi-Schrauber
Joined: 11/13/2002 Posts: 1142 Karma: +38 / -0 Location: Wien 2001 Audi A2  Premium Support
12-05-2009, 8:44 Subject: 1.9 TDI Head on 2.0 TDI Engine Conversion |
The BMM is a 16V engine.
The ATD has a voltage of 8V.
Nothing fits! / Nothing makes sense! / It doesn't fit at all!
Translated on 26-07-2026, 10:47.
Profile PM Garage |
winnie4get Blaumann
06-09-2009, 11:22 Subject: 8V vs 16V: Does DPF Matter? |
It's been a long time!
Hmm, I'm surprised. The BMM engine with a DPF has 8 valves, while the BMN engine with a DPF has 16 valves.
Okay, now it should be correct!
07-09-2009, 8:29 Subject: 1.9 TDI Head on 2.0 TDI Engine Conversion |
Winnie.
Please read your answer again because it contradicts itself.
And even if you replace an "without" with "with DPF" somewhere, I bet that a BMP file will result when using a DPF  .
Okay, please provide the German text you would like me to translate into English. I will only provide the translation. Transparency, Teamwork
Translated on 26-07-2026, 10:48.
Profile PM Garage |
teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
07-09-2009, 8:47 Subject: 1.9 TDI Head on 2.0 TDI Engine Conversion |
Hi, that's how I understand it too.
"8-valve engines with DPF (Diesel Particulate Filter) tend to have worse performance."
16 valves are already better from the factory. Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 26-07-2026, 10:49.
Profile PM Email Garage |
07-09-2009, 12:16 Subject: 1.9 TDI Head on 2.0 TDI Engine Conversion |
It's just a guess, but perhaps the 8V configuration was chosen for the DPF because one exhaust port heats up faster than two, which would bring the DPF to operating temperature more quickly.
This was at least practiced in this way by Deutsche Bahn (DB).
Translated on 26-07-2026, 10:50.
Profile PM Garage |
07-09-2009, 12:37 Subject: 1.9 TDI Head on 2.0 TDI Engine Conversion |
And with the BMR (16V PPD DPF), they then disregarded thermodynamics  .
My guess is that it would be better to experiment with separating the 16V system from the DPF.
Profile PM Garage |
07-09-2009, 12:43 Subject: 1.9 TDI Head on 2.0 TDI Engine Conversion |
Hmm, my guess is that when the 8-valve engine was due for a DPF (Diesel Particulate Filter), the 16-valve engine hadn't yet been developed with a DPF, so adapting it to the 8-valve engine was available more quickly.
Back then (I remember a G4), it was only available with an 8V engine and a DPF, while the 16V version was only offered without a DPF. I no longer remember the model codes. Gruß, der Teileklaus
Translated on 26-07-2026, 10:51.
07-09-2009, 15:00 Subject: 1.9 TDI Head on 2.0 TDI Engine Conversion |
That was the case with the 140 series until they were replaced by CR models.
Only the 170 hp engine was always equipped with a 16-valve DPF system. Transparency, Teamwork
Translated on 26-07-2026, 10:52.
Profile PM Garage |
07-09-2009, 17:03 Subject: 1.9 TDI Head on 2.0 TDI Engine Conversion |
dieselmartin wrote: | And with the BMR (16V PPD DPF), they then disregarded thermodynamics .
m; |
That was all there is to it.
Meanwhile, Mercedes has also managed to produce low-emission engines with four valves.
Translated on 26-07-2026, 10:53.
Profile PM Garage |
