VW 1Z Engine ESP Tax Signal (VP37)
Tenzing-Moagei
Post14-09-2009, 22:53    Subject: VW 1Z Engine ESP Tax Signal (VP37) Quote
Hello everyone,
Can anyone tell me what type of electrical signal a VP37 electronic control unit (ECU) for a 1Z VW engine receives for fuel injection (not the feedback signal)? Is it a 0-5V signal, a 0-10V signal, a 4-20mA signal, or a frequency signal?
I want to build a generator for emergency power (island mode operation), and for this, I need a constant speed. The entire system is controlled by a PID controller, with the motor speed being the controlled variable.
The feedback signal would also be quite informative, but I think I don't need it.
"A signal indicating a delay in the start of boost would be helpful. Can anyone help me understand if the boost start is only dependent on engine speed, or also on load? Actually, if I think about it, it should depend on both engine speed and boost pressure, right? Am I correct in that assumption? And what order of magnitude are we talking about here?"
Thank you for your help.
Tenzing-Moagei.
MOD: The 1.9 TDI engine with VP37 injection pump is designated 1Z.
Translated on 30-08-2026, 19:29.
No new posts Repair of a VP37 manifold Troubleshooting & Guides
No new posts Development of the 1.9 l TDI Engine Technical Articles
No new posts TDI Injector Replacement: DIY Guide & Tips Troubleshooting & Guides
This topic is locked, you cannot edit or reply. Can You Determine Engine Mileage? On-Board Diagnostics (OBD)
No new posts AFB Motor Suction Nozzle On-Board Diagnostics (OBD)
No new posts Engine Noise When Shutting Off Diesel Engine Technology
No new posts Volvo D5 Diesel Engine Technology Diesel Engine Technology
