Solenoid Valve: Troubleshooting Performance Loss
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Diesel Engine Technology
ttns4
Post12-02-2003, 13:07    Subject: Solenoid Valve: Troubleshooting Performance Loss Quote
Hello everyone,
Does anyone know the exact function of the solenoid valve?
above the LLM (Low-Level Module) on a Passat (PD, 85 kW, model year 2000).
is attached on the left side?
I suspect that this valve is the cause of the performance loss we've been searching for.
The part has an electrical connector and two hose connections.
It appears to be responsible for the pressure bypass that controls the turbocharger.
Problem: Intermittent power loss; the workshop, as usual, is unable to diagnose the issue.
I can imagine that the device occasionally just outputs its maximum power, which can result in acceleration delays and, sometimes, a reduced top speed.
So long icon_rolleyes.gif.
Thorsten.
Translated on 28-08-2026, 6:31.
Karma: +807 / -0   Thank you, like it!
Post12-02-2003, 14:17    Subject: Solenoid Valve: Troubleshooting Performance Loss Translating...
[Translating...]
http://www.dieselschrauber.de/tdischlauch.html
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0046 - Turbocharger Boost Control Circuit Malfunction, M... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Air Bubbles: Find the Root Cause & Fix It! Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Boost control solenoid valve. Power loss (A3 TDI) Diesel Engine Technology
No new posts Magnet Valve Failure: Vacuum & Pressure Issues Diesel Engine Technology
No new posts Boost Control Valve: Limit Charge Pressure Diesel Engine Technology
This topic is locked, you cannot edit or reply. Boost Control Solenoid Valve Diesel Engine Technology
