Used Tires: Factory Fresh, Great Prices
christians
Post27-09-2009, 20:56    Subject: Used Tires: Factory Fresh, Great Prices Quote
Hi everyone, I bought new summer tires a week ago. They are 205/55R16W, Continental SportContact. As soon as I drove off the lot, I noticed that the tires were exactly three years old.
According to common legal practice, they are still considered brand new, and I had no way to return them.
Therefore, I'm not writing this to praise them, because these officially new tires already heated up to more than body temperature at 50 km/h on a straight road, starting *within* the tread and also in the sidewalls, with the front being warmer than the rear, and the rear being particularly warm on the inside.
Consequently, the rolling resistance, which usually allows me to coast easily, caused me to slow down continuously.
After a week and approximately 350 km/h of driving in both city and highway conditions, the situation has significantly improved. The old tires were probably still cooler, but the issue is no longer noticeable.
I can only warn against using tires like these "new" ones before a long drive on the highway. I probably would have driven to every parking area just to check them manually.
Gruß Christian
Translated on 27-09-2026, 11:25.
teileklaus
Avatar-teileklaus
Karma: +12 / -0   Thank you, like it!
2005 Volkswagen
Post27-09-2009, 21:32    Subject: Used Tires: Like New, Factory Fresh Quote
christians wrote:
After a week and approximately 350 km/h of driving in both city and country conditions, the situation had clearly eased,
You shouldn't drive so recklessly with new tires, you hear? icon_rolleyes.gif
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 27-09-2026, 11:27.
christians wrote:
...after a week and approximately 350 km/h in city and country driving...
Subject: I also find it outrageous that tires that are 3 years old can still be sold as new. A piece of metal might still be the same after 3 years, but certainly not rubber. However, there's nothing we can do about it. So, be careful when buying tires.
Translated on 27-09-2026, 11:28.
christians
Post28-09-2009, 6:41    Subject: Used Tires: Factory Fresh, Great Prices Quote
Yes, that is the average of B7 and B515.
Gruß Christian
No new posts New Golf refused to connect to OBD scanner On-Board Diagnostics (OBD)
No new posts VP37: Common Issues & Problems in Old Age Diesel Engine Technology
No new posts Passat 3C Remote Key Fob Programming - Old Key On-Board Diagnostics (OBD)
No new posts Classic Audi Gas Engine: Diesel-Like Performance? Diesel Engine Technology
