Audi A6 2.5 TDI, Preheat lamp flashing (AAT)
qayyse
Post09-10-2009, 18:56    Subject: Audi A6 2.5 TDI, Preheat lamp flashing (AAT) Quote
I am Daniel, and unfortunately, I have a problem with my Audi. First, let's get the background information:
I recently acquired the Audi, with only 335,000 km on the odometer, from a reputable street dealer (you won't find cars like this at other export dealerships). And that's when the problems started. The car was a bargain so far, the only thing was that it idled loudly, I used the search function on this forum and found helpful information.
I cleaned and partially re-sealed the VP37 after getting a tip from this forum, and the sawing noise is gone. However, the indicator light has been blinking since then??
Initially, I monitored the settings using VAG-Com.
Fault memory displays the following message:
Code:
Part number: 4A0 907 401 F
Part and/or Version: 2.5l R5/2VT EDC AT D22
Encoding: 00000
Workshop Code: WSC 00000
1 Error found:
00765 - Actuator for Valve Actuation Path (G149)
27-10 - Unlikely Signal - Sporadically
Also, I also made a LOG:
Friday, 09, October, 2009, 18:23:06
4A0 907 401 F ,,2.5l R5/2VT EDC AT D22,
,Group A:,'000,,,,,,,,,,Group B:,, Not Running,Group C:,, Not Running
,TIME,,,,,,,,,,,TIME,,,,,TIME,,,,
MARKER,STAMP,,,,,,,,,,,STAMP,,,,,STAMP,,,,
,0.00,034,057,000,013,087,235,084,167,143,121,,,,,,,,,,
,0.38,033,056,000,016,087,235,084,167,143,120,,,,,,,,,,
,0.78,034,055,000,013,086,235,084,167,143,121,,,,,,,,,,
,1.22,033,057,000,015,087,235,084,167,143,120,,,,,,,,,,
,1.66,034,056,000,014,086,235,084,167,143,121,,,,,,,,,,
,2.11,033,053,000,015,087,235,084,167,143,119,,,,,,,,,,
,2.58,033,058,000,015,087,235,084,167,143,119,,,,,,,,,,
,3.04,034,055,000,013,087,235,084,167,143,122,,,,,,,,,,
,3.50,033,054,000,015,087,235,083,167,143,121,,,,,,,,,,
,3.95,034,055,000,013,086,235,083,167,143,121,,,,,,,,,,
,4.42,033,055,000,015,087,235,084,167,143,119,,,,,,,,,,
,4.86,034,056,000,013,087,235,083,167,143,121,,,,,,,,,,
,5.29,033,055,000,016,087,235,084,167,143,122,,,,,,,,,,
,5.68,035,055,000,011,087,235,083,167,143,121,,,,,,,,,,
,6.08,032,057,000,017,087,235,083,167,143,121,,,,,,,,,,
,6.49,035,055,000,010,086,235,083,167,143,123,,,,,,,,,,
,6.94,033,057,000,015,087,235,083,167,143,119,,,,,,,,,,
,7.39,033,055,000,014,087,235,083,167,143,119,,,,,,,,,,
,7.84,033,057,000,014,087,235,083,167,143,120,,,,,,,,,,
,8.30,033,058,000,015,087,235,083,167,143,120,,,,,,,,,,
,8.77,034,058,000,012,087,235,083,167,143,123,,,,,,,,,,
1.  23.033.059,000.015.087.235.083.167.143.120,,,,,,,,,,
,9.71,033,055,000,014,087,235,083,167,143,122,,,,,,,,
,10.17,033,059,000,015,087,235,083,167,143,119,,,,,,,,,,
,10.62,033,056,000,014,087,235,083,167,143,120,,,,,,,,,,
,11.05,034,058,000,014,086,235,083,167,143,123,,,,,,,,,,
,11.50,033,057,000,014,087,235,083,167,143,124,,,,,,,,,,
,11.90,033,058,000,016,087,235,083,167,143,117,,,,,,,,,,
,12.30,035,059,000,012,087,235,083,167,143,124,,,,,,,,,,
Based on the values I can assess, they seem to be within the acceptable range, except possibly for the injection start timing, which is quite high, but still within the specified limits.
If I then increase the injection amount, or the value, the light no longer flashes, however, I experience a noticeable loss of power and extremely high fuel consumption (7.5 to 11.5), furthermore, the engine starts poorly and also responds poorly to acceleration.
I hope I haven't forgotten anything and that the text above will help with the diagnosis.
Thank you in advance.
Gruß Daniel
Audi A6 (C4) Avant 2,5 TDI Autom. Bj. 1995
S/4A5/Audi100/A6 Avant/AAT/CDS
Klilometerstand: 335137km (Stand 9.10.2009)
No new posts Glow plug light flashing Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Polo MJ 2001, Climatronic display blinking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Glow plug light flashing - ASZ TDI PD Diesel Engine Technology
No new posts Power Cord/Glow Plug Flashing: Troubleshooting Diesel Engine Technology
This topic is locked, you cannot edit or reply. Glow plug light flashing, DPF and engine check lights on! Diesel Engine Technology
No new posts Glow Plug Light Flashing: DPF & Engine Error Codes Diesel Engine Technology
