Measuring VCDS compression?
Search
Automotive Technical Articles
Bookmarks
Links
Garage
Books / Tools
FAQ, Legal Notice & Privacy
RSS Feed
Register
Login
DE
EN
IT
New Topic
Reply
Dieselschrauber - Index
On-Board Diagnostics (OBD)
View previous topic
View next topic
Author
Message
chriskross
18-10-2009, 15:02
Subject: Measuring VCDS compression?
Quote
"Hi, can you measure cylinder compression with VCDS? According to this thread, it should be possible."
[Link to Motortalk]
Can someone tell me how to do this with VCDS?
best regards, chris
A6 AFB
A6 BRE DPF
Translated on 12-07-2026, 5:38.
Profile
PM
2018 Volkswagen T6
18-10-2009, 15:05
Subject: Re: Measuring compression with VCDS?
Quote
chriskross wrote:
kann mir jemand sagen wie das mit vcds geht?
Not at all
There are no cylinder pressure sensors that can be queried, and the sampling rate via diagnostics is likely too low to meaningfully evaluate the onboard voltage/current draw of the starter motor.
Dipl.-Ing. (FH) Rainer Kaufmann -
Original VCDS mit KPower, KDataScope und Dieselschrauber Support
Translated on 12-07-2026, 5:39.
Profile
PM
WWW
Garage
New Topic
Reply
View previous topic
View next topic
Topic
Forum
Brake Bleeding with VCDS: A Complete Guide
Train T90 / T 91 with VCDS
Battery Status with VCDS
Measuring boost pressure with VCDS RKS 12.12
Gasoline Engine Technology
AFB - Kompression
Diesel Engine Technology
Oil Temperature: Where to Measure It?
Coolant Temperature Measurement: How To & Guide
Select a forum
Diesel Motorentechnik
Benziner Motorentechnik
On-Board-Diagnose (OBD)
Dieselschrauber Bar
Allgemeine Tipps
KFZ-Technik-Artikel
Fehlersuche & Anleitungen
Technische Daten
Fachartikel
Weblogs
KFZ-Technik Quiz und Halden
Quiz
Upload
Schrotthalde
You
cannot
Foren- und Portal-Software: V7.8 © 2003 - 2026
Kaufmann Automotive GmbH
Embedded Software Freelancer
Shop für Kfz-Diagnosegeräte
. Parse time: 0.072s
