2.0 TDI BKD: AGR Valve Problem?
Deus Violentia
Post09-11-2009, 17:24    Subject: 2.0 TDI BKD: AGR Valve Problem? Quote
Today I discovered that the area behind my EGR valve is very oily and dirty, so I removed the EGR valve and the throttle body. I'm not sure where this contamination is coming from. It's located behind the EGR valve, on the cylinder head, engine block, and intake manifold. The intake manifold itself doesn't seem to be the cause.
"I was shocked to see what the EGR valve looked like after only 20,000 km. There was a 3mm thick layer of soot all around, which is definitely not normal! I cleaned it thoroughly before installing it. I strongly suspect that the dirt is escaping from the EGR valve outwards through the hole visible in the photo. Is that possible, or is it unthinkable? What is the purpose of this hole under the pressure sensor? The driving behavior is normal."
How can the engine control unit be modified so that blocking the EGR pipe with a plate does not trigger an error, or to what extent can the feedback rate be reduced using VCDS?
Thank you for your help!
http://pu.polo9n.info/qgrLd42CGHVmCU5rvthX.jpg
http://pu.polo9n.info/PkqrzRFPu8Bnwrx7XPbS.jpg
Translated on 10-10-2026, 8:50.
Post09-11-2009, 17:53    Subject: 2.0 TDI BKD: AGR Valve Problem? Quote
The hole is the reference air vent. If anything comes out of it, the part is defective. This happens very often.
You can't adjust the AGR rate using VCDS on a BKD engine. Ask Rainer; he can help with that.
Translated on 10-10-2026, 8:51.
No new posts Audi A4, A5, A6, A7, Q5, Q7 3.0 TDI, Oil in the vacuum sy... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI BKD/AZV from 2004, Whistling/Squealing noise unde... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts VW Recall: Buy Auto Bild or Read Online Diesel Engine Technology
No new posts 2.0 TDI (BMN) Are your PD elements clogged or misconfigured? Diesel Engine Technology
This topic is locked, you cannot edit or reply. VW Passat 2.0 TDI CR 125kW Exhaust temperature sensor (G2... Diesel Engine Technology
No new posts Wheel Bearing Problems? Diagnose and Repair. Transmission, Chassis, Body & Interior
