since it might not have been noticed yet,
I would like to officially announce here that the newer...
"The 'weaker' PD TDIs do not have water-cooled pistons (as some do)."
"They had more than was common at the beginning of the PD."
This applies to the 77kW/105PS 1.9-liter engine.
In this specific case, it was a BLS, where the BKC...
ziemlich sicher die gleichen Kolben (lt. It has an ET- number.
It would also be interesting to see what the "2.0" versions look like.
Has anyone here ever taken one apart before?
täte mich auch ma interessieren, wie sieht denn so ein Kühlkanalkolben aus im Vergleich zu den anderen?
He has a cooling channel .
Just kidding,
A ring groove is located inside the piston bowl rim to provide thermal relief. When the piston moves downwards, the oil jet nozzle directs oil into the groove.
