Passat 3C Rear Brake Adjustment Procedure
vwSchrauber
Post06-11-2009, 12:01    Subject: Passat 3C Rear Brake Adjustment Procedure Quote
Brake adjusted to default setting, bleed valve (MWB) 007 opened, brake caliper removed.
Now the question arises: how do you reset the piston?
Does it connect via threads, as was common in older systems?
"Thank you."
Greetings.
John.
Translated on 07-08-2026, 1:48.
vwSchrauber
Post06-11-2009, 13:05    Subject: Passat 3C Rear Brake Adjustment Procedure Quote
It's been taken care of.
After some trial and error, it could now be adjusted with a feel for the right amount of force, and then locked into place.
Threads, as usual icon_smile.gif.
Translated on 07-08-2026, 1:49.
Arne
Post09-11-2009, 13:13    Subject: Passat 3C Rear Brake Adjustment Procedure Quote
Yes, you can easily revert to the previous setting. For example, with the A8, you still have to manually enter the pavement thickness later, but with the A6, that's not necessary. I don't know about the Passat right now.
Greetings.
Translated on 07-08-2026, 1:50.
Post09-11-2009, 13:47    Subject: Passat 3C Rear Brake Adjustment Procedure Quote
Arne wrote:
...that doesn't apply to the A6. I don't know about the Passat right now.
Exactly. Just set the basic settings at the end, and you're done.
bloesch
Post10-11-2009, 9:33    Subject: Passat 3C Rear Brake Adjustment Procedure Quote
small note / brief comment.
For models with the electric parking brake, the piston (like on the front) can be retracted. It doesn't need to be rotated.
Translated on 07-08-2026, 1:51.
No new posts Golf 1J: Rear Clicking Noise - Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Workshop action Polo MJ 2000, rear brake hose Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J Repair: Rear Hatch Lock Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Rear Door Panel Passat 3B Transmission, Chassis, Body & Interior
No new posts VW Passat Rear Door Won't Open - Fix! Transmission, Chassis, Body & Interior
No new posts Passat Variant - Rear bumper, assembly Transmission, Chassis, Body & Interior
No new posts Passat 3B Rear Shock Absorber Torque Specs Transmission, Chassis, Body & Interior
