VW Passat Driver Door Won't Open - Fix!
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
elyias1
Post27-11-2012, 0:10    Subject: VW Passat Driver Door Won't Open - Fix! Quote
My wife drives it, and unfortunately, more and more defects are appearing.
The latest problem I'm having is with the driver's side door. I've done some research online and have come across potential issues such as a faulty cable or problems with the electrical contacts in the lock.
I ran the diagnostic scan, and the error message indicates an electrical problem. Is this more likely a contact issue or a stuck cable that's blocking the lock?
Sunday, November 25, 2012, 18:16:05:45503.
VCDS version: RKS 11.11.4
Data as of: 20120807.
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den BĂ€umen. Ein leichter Wind weht durch das Gras. Es ist ein perfekter Tag fĂŒr einen Spaziergang."
Vehicle type: 3C0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72 77 7D
Vehicle Identification Number (VIN): WVWZZZ3CZ6P023613 Mileage: 219,020 km
00-Steering angle sensor -- Status: OK 0000
01-Motor -- Status: OK 0000
03-Brakes -- Status: OK 0000
08-Climate Control/Heating -- Status: OK 0000
09-Onboard network -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-inch steering wheel -- Status: OK 0000
17-in-1 instrument -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
Immobilizer system -- Status: OK 0000
42-Door Electric Driver -- Status: Error 0010.
Steering assist - Status: OK 0000
46-Comfort System -- Status: OK 0000
52-door electric passenger side door - Status: OK 0000.
53-Parking brake -- Status: OK 0000
56-Radio -- Status: OK 0000
62 - Door, electric, left and right -- Status: OK 0000
Door 72, electric hinge, right side - Status: OK 0000.
77-Phone -- Status: OK 0000
7D Auxiliary Heater -- Status: OK 0000
Post
Posted on: 2012-11-26, 23:10
Title: Driver's door on Passat 3C no longer opens from the outside.
"The latest problem I'm having is with the driver's side door. I've done some research online and have come across potential issues such as a faulty cable or problems with the electrical contacts in the lock."
Vehicle type: 3C0
Mileage: 219,020 km
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den BÀumen. Ein leichter Wind weht durch das Gras. Es ist ein wunderschöner Tag."
"The sun is shining brightly and warmly. The birds are chirping happily in the trees. A gentle breeze is blowing through the grass. It's a beautiful day."
Address 42: Door electrics. Driver label file: RKS\1K0-959-701-MIN2.lbl.
Part number: 1K0 959 701 K
Component: Door seal 024 2359.
Encoding: 0000181
Operating number: WSC 00028 028 00001.
VCID: 366561B141F6C2A8CBB
"2 errors found:"
01552 - Motor for central locking system, driver's door (V56); LOCK.
012 - Electrical fault in the circuit.
00928 - Driver's side central locking control unit (F220).
008 - implausible signal.
Address 46: Comfort System
Label file: RKS\3C0-959-433-46.clb
Part number SW: 3C0 959 433 H, HW: 3C0 959 433 H.
Component: KSG PQ46 ELV 038 0453
Revision: 00038000 Serial Number: VWZCZ000000000
Encoding: 00910A0801860E763804941570084F0E703C00
Operating number: WSC 40339 146 126651.
VCID: 2F6B54D5BEACF36088D
Part number: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS, not mounted.
Component: IRUE, not mounted.
No error codes found.
Address 52: Power door lock, front passenger side. Label file: RKS\1K0-959-702-MIN2.lbl
Part number: 1K0 959 702 K
Encoding: 0000180
VCID: 377B6CB546FC3BA0D0D
Thank you for your help.
Edit Autoservice: Log file shortened.
Passat 3C 2.0 TDI BMP 6 Gang Schalter
Fabia 2.0
Pontiac Transsport 2.3 Schalter
"Am Ende wird alles gut. Wenn es nicht gut ist, dann ist es nicht das Ende..." Oskar Wilde
Translated on 24-08-2026, 9:00.
Post27-11-2012, 1:07    Subject: VW Passat Driver Door Won't Open - Fix! Quote
Possibly a feather is stuck in the lock - the door opener is jammed when pulled.
Relief can be achieved by deburring the feather and lubricating it thoroughly.
Tip: Use a suitable multi-spline socket on one of the three mounting screws (on the outside of the lock) and tap it gently with a small hammer (100 grams).
With a bit of luck, the lever will snap back into its original position.
 OK - Hebel geht wieder in Ausgangslage
 File size:  1.78 MB
 Viewed:  21425 times
 verklemmt
 File size:  1.85 MB
 Viewed:  30213 times
*Nichts ist einfacher, als sich schwierig auszudrĂŒcken......*
Translated on 24-08-2026, 9:16.
Post27-11-2012, 1:12    Subject: VW Passat Driver Door Won't Open - Fix! Quote
This aligns with my experience of encountering the same error.
Fiddling around with it randomly fixed the problem.
Translated on 24-08-2026, 9:17.
No new posts Roomster Tailgate Won't Open: Remote Button Issue Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Radio Problem: Fix for 8L Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Driver's door won't open Transmission, Chassis, Body & Interior
No new posts Passat 3B Rear Door Won't Open? Transmission, Chassis, Body & Interior
No new posts CV Joint Boot Replacement - Passat B5 PD Transmission, Chassis, Body & Interior
No new posts Passat 3B AHU won't start Diesel Engine Technology
