Rear Axle Noise: Causes and Solutions
Markus0
Post16-02-2003, 14:40    Subject: Rear Axle Noise: Causes and Solutions Quote
When I pull the handbrake or press the brake pedal on my VW Bora TDI, something makes a cracking sound at the rear. This also happens when I manually push the rear shock absorbers.
What is that?
Translated on 17-08-2026, 13:45.
Michael II
Post16-02-2003, 19:23    Subject: Rear Axle Noise: Causes and Solutions Quote
Hello Markus,
What is the model year?
Tschüss
Michael II
MelleTom
Post17-02-2003, 16:09    Subject: Rear Axle Noise: Causes and Solutions Quote
Is the spring in place? Otherwise, it will rub against the axle body.
Translated on 17-08-2026, 13:46.
bergmike70
Post27-02-2003, 14:08    Subject: Rear Axle Noise: Causes and Solutions Quote
It could be a brake pressure regulator!
Michael II
Post05-03-2003, 21:20    Subject: Rear Axle Noise: Causes and Solutions Quote
There is now information available on this topic in the error/knowledge database.
Tschüss
Michael II
No new posts Cracking noise from rear axle, Audi A6 4F Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Caddy 9K Rear Axle Noise (1998) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document 1J, Clicking, Squeaking at the rear axle Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Sharan 7N: Valve Block Crack Repair Transmission, Chassis, Body & Interior
No new posts Front Axle Noise: Causes and Solutions Transmission, Chassis, Body & Interior
No new posts Front axle cracking - Sharan 7N Transmission, Chassis, Body & Interior
No new posts VA Noises? Worn Ball Joints - Diagnose & Repair Transmission, Chassis, Body & Interior
