EDS System Error: Troubleshooting & Fixes
marcello
Post15-02-2003, 13:09    Subject: EDS System Error: Troubleshooting & Fixes Quote
The EDS (Electronic Differential Lock) in my friend's Seat Cordoba is engaging too early.
"That means that when you drive the car slowly around a curve, the hydraulic pump already turns on. I read the error memory."
"There was nothing there, so I then measured the individual wheel speeds under the measurement block, but they were all approximately the same."
(slight deviations are possible) of course, not when cornering! The car was manufactured in 1998 and has a Teves ABS-EDS system.
Has anyone else experienced problems like this?
Thank you for any help.
MARCELLO
Translated on 29-09-2026, 3:37.
Back to top Profile PM Email
Michael II
Post15-02-2003, 16:18    Subject: EDS System Error: Troubleshooting & Fixes Quote
Hello Marcello,
What type of TV is it (e.g., Mark30...)?
What speed was the car traveling at when it entered the curve?
Tschüss
Michael II
Translated on 29-09-2026, 3:38.
marcello
Post18-02-2003, 12:41    Subject: EDS System Error: Troubleshooting & Fixes Quote
Okay, so it's an ITT Mark 20 ie ABS-EDS system with CAN-BUS.
As I originally intended, a Teves ABS.
and this phenomenon only occurs at very low speeds, up to approximately 5 km/h.
auf
Please urgently find a solution.
Thank you in advance.
MARCELLO
Translated on 29-09-2026, 3:39.
Thomas K.
Post18-02-2003, 12:55    Subject: EDS System Error: Troubleshooting & Fixes Quote
just a side note:
ITT, ATE, Teves, and Continental Teves are all from the same manufacturer, operating under the umbrella of Continental.
marcello
Post18-02-2003, 13:00    Subject: EDS System Error: Troubleshooting & Fixes Quote
Okay, that's good! But please help me solve this problem.
Translated on 29-09-2026, 3:40.
No new posts A4/A6 Doku: Faulty Fan Control System Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3: Faulty Fan Repair & Service Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbocharger Boost Control Problem - Golf4 AXR Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Outdoor Temperature Display Malfunction! Diesel Engine Technology
No new posts Steering Sensor Error: Replaced Slip Ring, ESP Light On On-Board Diagnostics (OBD)
No new posts Golf 4, 2000, APF, Secondary air pump - Faulty shift signal Gasoline Engine Technology
No new posts Audi A6 Error 01117: Load Signal Fault Diesel Engine Technology
