Ruffy Blaumann
Joined: 12/05/2009 Posts: 109 Karma: +2 / -1 Location: Aachen
14-06-2010, 9:10 Subject: 2.5 TDI: Parts in the oil pan |
Morning!
Okay, moving on to my second problem of the day... When I had the car on the lift the other day, I took the opportunity to replace the oil pan gasket. It was leaking badly. While I was doing that, I noticed that there were two small pieces stuck in the oil pump strainer. I then found a third one in the oil pan.
They are round discs, approximately 5-7mm in diameter. They are about 3mm high, with a depression on one side and a rectangular functional area on the other. They don't appear to be insignificant! I have no idea where they come from.
I'm already suspecting it's a valve drive mechanism...
Best regards, Marcus.
14-06-2010, 9:18 Subject: 2.5 TDI: Parts in the oil pan |
Photo?!
Profile PM Garage |
14-06-2010, 9:24 Subject: 2.5 TDI: Parts in the oil pan |
dieselmartin wrote: | | Photo?! |
Right, without that, it's hard to say anything definitive.
Everything is back to normal, sorry, my mistake.
Profile PM Garage |
Ruffy Blaumann
14-06-2010, 11:09 Subject: 2.5 TDI: Parts in the oil pan |
Okay, here's a photo of the little ones:
 " color="red">Bitte keine Links zu externen Dateihostern! a) nerven die zusätzlich notwendigen Klicks, b) Wartezeit, Werbebanner/Werbepopups und notwendige Registrierungen, c) ist nach einiger Zeit die Datei weg und das Thema für andere Leser nutzlos! Bitte nutze 'Attachment hinzufügen' bzw. das Upload Forum hier. /img32/5412/14062010194.jpg" class="responsive" alt="http://img32.
Bitte nutze 'Attachment hinzufügen' bzw. das Upload Forum hier. /img32/5412/14062010194.jpg" onLoad="imgResize(this);" onMouseOver="imgCursor(this);" onClick="imgOpenResized(this);">
christians Profi-Schrauber
14-06-2010, 12:03 Subject: 2.5 TDI: Parts in the oil pan |
Yes, you guessed it. "If the pushrods weren't so big, they would still be down there."
Gruß Christian
14-06-2010, 12:16 Subject: 2.5 TDI: Parts in the oil pan |
Yes, those are the pressure pieces where the rocker arms press down.
Profile PM Garage |
Ruffy Blaumann
14-06-2010, 12:17 Subject: 2.5 TDI: Parts in the oil pan |
And what exactly are those parts? So, what is their purpose?
I know that the car has already had new camshafts and rocker arms installed. Now the question is, whether these are still the ones from back then, or if they're just breaking down again.
Marcus
Edit: Okay, question answered!^^ Then I guess the lids have to come off...
Ruffy Blaumann
22-06-2010, 11:13 Subject: 2.5 TDI: Parts in the oil pan |
Enjoy your meal!
Here's some news: I haven't been back to my local workshop yet, but today I took a look at the oil drain plug: It doesn't look good!!
- If I look inside, I immediately see a broken rocker arm lying around near the camshaft. Therefore, the parts in the oil pan were not damaged beforehand.
- Also, the first camshaft lobe is worn down by 1mm! When I last checked there, 2000 km ago, the camshaft lobe was in perfect condition! Apparently, the previous owner replaced the camshafts with cheap, low-quality parts. That's not good. The second... Nocken, on the other hand, looks great again...
Before I start fixing anything: It's now pretty clear what causes the rocker arms to break. I've read various theories about this in the forum. Are these things simply too weak, or is it due to the hydraulics, or something else?
mserge Schrauber
Joined: 06/20/2005 Posts: 923 Karma: +6 / -0 Location: Luxemburg
22-06-2010, 16:29 Subject: 2.5 TDI: Parts in the oil pan |
I would say that some substandard materials were used, or that things weren't done correctly, and that inferior quality parts were substituted. If the parts were replaced with original parts at some point, they should last, assuming proper maintenance.
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
Tagessuppe Profi-Schrauber
Joined: 11/13/2002 Posts: 1142 Karma: +38 / -0 Location: Wien 2001 Audi A2  Premium Support
22-06-2010, 22:16 Subject: 2.5 TDI: Parts in the oil pan |
My condolences!
Which brand, or where did you buy the sentence from?
Profile PM Garage |
Ruffy Blaumann
22-06-2010, 23:24 Subject: 2.5 TDI: Parts in the oil pan |
Good evening!
Thank you for your condolences! I still can't believe that a camshaft could disintegrate like that, even with proper care... I also think that the quality is the problem. The camshafts are likely unevenly hardened, which is why one cam lobe is good and the other is bad...
I don't know where they came from... the previous owner did that, and I bought the car after that.
But let's go back to the lifter levers: Why are they being phased out now? Is that also related to the camshafts, or is it a separate issue?
By the way, I don't enjoy driving at all! The idle is great, and I still have very, very good performance.
23-06-2010, 11:39 Subject: 2.5 TDI: Parts in the oil pan |
The latch levers are not held in place, but are only "clipped" or "secured" in that position. If the camshaft lobes wear out or the hydraulic lifters are flattened, there will be excessive clearance.
Gruß Christian
Ruffy Blaumann
24-06-2010, 0:12 Subject: 2.5 TDI: Parts in the oil pan |
Thank you for the response! And are these new ones designed differently so that they don't fall out as easily?
Normally, working hydraulic systems should always maintain pressure... or shouldn't they?
24-06-2010, 8:04 Subject: 2.5 TDI: Parts in the oil pan |
Ruffy wrote: | | Normally, working hydros should always keep the pressure up... or not? |
To a certain extent, yes. However, if too much is missing, it can't be compensated for. The Hydros don't have a commute of 5cm either.
Profile PM Garage |
24-06-2010, 19:58 Subject: 2.5 TDI: Parts in the oil pan |
Also, the hydrants don't always work either.
Gruß Christian
Ruffy Blaumann
24-06-2010, 23:49 Subject: 2.5 TDI: Parts in the oil pan |
TDI-GTI-4-Motion wrote: | Ruffy wrote: | | Normally, working hydros should always keep the pressure up... or not? |
To a certain extent, yes. However, if too much is missing, it can't be compensated for. The Hydros don't have a commute of 5cm either.  |
Are the working clearances of the hydros very small? I mean, the wear on the shafts is only a matter of millimeters. I estimate that driving becomes impossible at around 2mm.
christians wrote: | | Also, the Hydros don't always work either. |
What do you mean by that? If they are broken or something?
Marcus
