Climatronic control unit adaptation
matzidererste
Post09-12-2005, 16:24    Subject: Climatronic control unit adaptation Quote
Hello.
I want to modify the Climatronic control unit for a Seat Leon to enable its operation with a auxiliary heater.
The Climacodes allow access to various control channels, enabling the adjustment of the airflow ratio between the upper part of the cabin and the footwell, for example.
Unfortunately, these changes are only temporary and are lost again when the ignition is restarted.
Can someone help me figure out how to save the changes permanently?
Is there a login code required to make adjustments in the control unit?
Ross-Tech-Support
Post09-12-2005, 18:16    Subject: Re: Climatronic control unit adaptation Quote
Actually, the "10 - Adaptation/Calibration" field should be disabled, meaning the control unit doesn't support adaptation. In that case, even logging in won't help.
...why do people always think that logins solve problems?! icon_confused.gif
matzidererste
Post09-12-2005, 18:31    Subject: Climatronic control unit adaptation Quote
The customization button is not disabled.
I can select the channels. However, the word "error" is displayed here.
I can only access the adaptation channels of the engine control unit after logging in. Previously, we only displayed errors.
Is it definitely not possible to make any adjustments?
Is the software in the control unit unchangeable?
Ross-Tech-Support
Post09-12-2005, 18:46    Subject: Climatronic control unit adaptation Quote
I can only access the adaptation channels of the engine control unit after logging in. Before, we only saw error messages.
Normally, with KWP-1281, I wouldn't expect a login to be possible, but I'm not ruling it out.
Is it definitely not possible to make an adjustment??
At least, no adjustments for customer service have been announced.
Most likely not, but the question is whether the manufacturer actually intends to make an adjustment, or whether these changes will be implemented through parameterization.
Smithi83
Post10-12-2009, 0:17    Subject: Climatronic control unit adaptation Quote
Hello everyone,
I'm also in the process of installing a Thermo Top C in my Leon right now... and I'm having the same problem.
I got an installation guide for the Golf 4... the issue is whether the Climatronic system has a built-in heater program or not.
Hmmm, did Seat install this, or is it not generally available in Spain?
Okay, so here's the translation:
"The fact is, I tried searching for and connecting to the specified D1 pin recently... but it's already in use!"
VW Touran AVQ Bj2003
BMW E46 330d EX91 BJ2004
Chevrolet Cruze Z20D1 Bj2013
VW Käfer 1200 BJ1983
No new posts Document startup issues, adjusting initial quantity Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Reading Faults - VW Climatronic from Hella Troubleshooting & Guides
No new posts Error code Climatronic 3B, model year 1999, 2000 model Troubleshooting & Guides
No new posts Removing the Climatronic control unit from a Volkswagen G... Transmission, Chassis, Body & Interior
No new posts Tire Size Adjustment for VW T4 On-Board Diagnostics (OBD)
No new posts Modify STG 46 settings On-Board Diagnostics (OBD)
No new posts MKB BKD: Engine Control Unit Tuning/Remapping On-Board Diagnostics (OBD)
