Noise when steering at full lock
RaZoR
Post25-02-2003, 17:37    Subject: Noise when steering at full lock Quote
'Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien.'
When starting in first gear with the steering wheel turned almost fully (either left or right), a grinding noise/vibration can be heard.
It all happened after a transmission change.
The friendly person suggested it might be the power steering pump, but I'm ruling that out.
Golf IV, AJM engine, 115 horsepower, 6-speed transmission, 45,000 km.
Thank you.
See you.
Razor.
Translated on 06-07-2026, 20:14.
Juergen
Post26-02-2003, 9:26    Subject: Noise when steering at full lock Quote
Have you ever checked the power steering fluid level?
If not, then follow these steps:
Start the engine.
Open container lid.
Let the assistant turn the steering wheel from lock to lock.
If the water level drops, it means there is air in the system!
Air in the hydraulic system manifests as squealing noises, but not only during startup, but whenever the pump needs to deliver high pressure (e.g., when the steering is at its limit).
Jürgen.
Translated on 06-07-2026, 20:16.
christians
Post26-02-2003, 14:47    Subject: Re: Noise when steering at full lock Quote
If the noise occurs 1. even when the steering is almost fully turned, and not just when the steering wheel is turned to its limit, and 2. only while driving, then it is likely not the power steering pump.
Gruß Christian
Translated on 06-07-2026, 20:17.
RaZoR
Post26-02-2003, 20:53    Subject: as I already said... Quote
... The phenomenon has only been present since the transmission was replaced.
And only when starting in first/reverse gear do you notice...
Even when the steering isn't perfectly aligned...
'But definitely something is wrong... at least that's what I claim. icon_cry.gif'
No new posts Noise / Clutch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance deficiency, piercing noise, nuclear... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Caddy 9K, from KW26/97, Loud Noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Schleifen/Krazen bei vollem Lenkeinschlag während Anfahrens Transmission, Chassis, Body & Interior
No new posts Limit Steering Angle Golf IV TDI Transmission, Chassis, Body & Interior
No new posts ESP-Sensor für Lenkeinschlag - Was genau wird gemessen ? Transmission, Chassis, Body & Interior
No new posts knarrendes Geräusch Transmission, Chassis, Body & Interior
