teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
10-09-2009, 13:16 Subject: |
Hello Rainer, I'm trying to reset the parking brake on my A6 to its default settings. I'm using the code 53-04-007, but I can't find the option to confirm the reset. Even with 010, pressing the button three times up and down doesn't do anything.
Looking for new updates because it's an A6 from the year 2008.
I don't see any new responses. I think it's working as it should, but how do I access it?
Can you help me?
Is it possible that I have to completely install the new version 9 and uninstall the old version 8?
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 05-10-2026, 11:34.
Profile PM Email Garage |
10-09-2009, 13:51 Subject: |
Hi Klaus, you can just overwrite the 908.0.
Already found it.
My customer had tampered with the motors, and as a result, the system wouldn't function properly. Error messages related to the motors or wiring kept appearing, and it wasn't until he reset the activation sequences to 0 that the errors cleared and the system started working again.
Translated on 05-10-2026, 11:35.
Profile PM WWW Garage |
10-09-2009, 17:33 Subject: |
Yes, Rainer, thank you. That was a silly question. Of course, there are no more updates for the older version, so that's how I did it.
Following the instructions, I proceeded with the A6, but I'm stuck after opening the brake system.
I'm going to start a new thread instead, as it's better than posting here.
Translated on 05-10-2026, 11:36.
10-09-2009, 17:41 Subject: |
Quote: | | I can't seem to get any further after releasing the brake. |
Why, what happens in measurement block 6 during the initial calibration?
Sure, here's the translation:
"PS: You can still detach the topic."
Translated on 05-10-2026, 11:37.
10-09-2009, 17:58 Subject: |
teileklaus wrote: | FZ A6, 2.7 TDI, 2008, Sedan.
Following the instructions, I selected the following points: "Chassis," "Parking brake 53," "Basic adjustment 04," and then "Open 07" to renew the SBB (likely a system component). I then tried to close it again using a button that I couldn't find. Now, I'm only able to open and close it using "010" three times. Now, I'm getting an error message that says "Basic adjustment not performed," and a large warning in the instrument cluster that says "Parking brake defective."
"The error message cannot be reset. I turned off the ignition during the installation, which, according to Audi, is incorrect."
I have installed the new version 9.
AUDI addresses the issue with a guided troubleshooting process and allows the ignition to remain active for a certain period.
There, the process is done step by step, with confirmation of the work completed. A "3 times attempt + delivery" is not included in that process. |
Okay, and what about measurement block 6, as mentioned in the instructions?
Translated on 05-10-2026, 11:38.
10-09-2009, 18:01 Subject: |
You're right, Rainer, but I thought that was something that had already been addressed in the previous A8 discussion...
Translated on 05-10-2026, 11:40.
10-09-2009, 18:12 Subject: |
 Ok.
10-09-2009, 18:22 Subject: |
Okay, then I'll try it sometime without changing the SBB (sensor/actuator block) – or is it absolutely necessary to retract the brake piston beforehand so that the basic setting for the control unit is plausible?
Your green smiley face reminds me of mine (except without the smiling), when things weren't going well...
Translated on 05-10-2026, 11:41.
10-09-2009, 18:53 Subject: |
Simply dial MWB 6. Do you now have 2 bricks in the trunk?
10-09-2009, 20:10 Subject: |
"I can't reach MWB 6 anymore, Rainer, because I already dropped off the car after Audi reset it. I just drove there, and they were very friendly."
Aber, das ist schon ein Technischer Gag, überfüssig und teuer durch die Rücksetzerei. AuShe's groaning too.
"What? Bricks in the trunk, what are you talking about? Am I hallucinating, or is it the beer?"
By the way: Thank you for the free update 9... and the quick response  .
Translated on 05-10-2026, 11:42.
10-09-2009, 20:51 Subject: |
Bricks as a mechanical handbrake
As long as the parking brake functions correctly, it might be nice that adjustments to the cable/handbrake lever are no longer necessary. Also, it creates more space in the center console.
I can't really think of anything else positive to say... because I don't need things like parking assist.
Translated on 05-10-2026, 11:43.
10-09-2009, 21:01 Subject: |
"It was working fine when I handed it over. I just wanted to test it again by dialing 7 and 6, just in case."
Great, then it should work out.
P.S. The 2 bricks are already reserved: I need them for my Fiat 500 and the Touran needs them for the accelerator pedal.
Translated on 05-10-2026, 11:44.
17-12-2009, 12:15 Subject: |
Hello Rainer, it's that A6 parking brake problem again.
Today, the car came back with the squealing brakes, and I'm unable to access Block 7 to open it and replace the brake pads.
FZ A6 2008 4F0910801C
Stgr 53
Basic salary: 04.
"Bucks cannot be activated, neither 0 nor 1."
I had actually been in there before, but I didn't know about the "6" button to reset it back then.
VDCS Version 1.81, Hex USB CAN.
Label file 4F0-910-801, LBL.
Requires driver 03-01-18 / 02.04.18.
auf dem befindet sich /00.04.00
Is that related?
"No update required."
Translated on 05-10-2026, 11:45.
17-12-2009, 14:37 Subject: |
Quote: | Because I don't need any of that extra stuff, like parking assist.
As an assist for getting the car moving, the electronic brake is also far too slow; it just chokes the engine.
Auto-Hold is much nicer in that regard  .
Translated on 05-10-2026, 11:47.
Profile PM Garage |
17-12-2009, 19:08 Subject: |
Hello Klaus,
How do you request a driver?
The "correct" driver for the HEX-USB+CAN is the one that comes with version 908.1.
Without drivers, nothing works; you can't even get into the system.
Translated on 05-10-2026, 11:48.
17-12-2009, 20:46 Subject: |
Hi Rainer,
When I check for updates, it tells me there's nothing new, and then it shows me driver numbers and says I should install them.
Sure, I can access the other control units.
I also ran a quick error scan, and it detected the MSG file.
Also measurement blocks as well.
Only in room 53 does the basic setting work; in block 1, rooms 05, 06, 07, and 10 don't work.
Or maybe I'm doing something fundamentally wrong  .
Translated on 05-10-2026, 11:49.
