Comfort lock, Passat 3B, year 1998
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Kradmelder
Post19-02-2003, 9:05    Subject: Comfort lock, Passat 3B, year 1998 Quote
Hallo zusammen, when I open the doors of my Passat 3B, 1998, using the door lock and holding the key in the unlocked position, and vice versa, all the windows (except the front and rear windshields, haha...) open and close. What's not working anymore is that when I press the window button for the driver's window to open, I have to hold the button down. Previously, I only needed to tap the button and the window would go all the way down. What could be the cause? And one more question? Do the buttons also need to be pressed for an extended period of time?
Kradmelder
Marco
Post19-02-2003, 16:08    Subject: Comfort lock, Passat 3B, year 1998 Translating...
[Translating...]Fahr das Fenster ganz herunter und halte den Knopf gedrückt
bis ein Klacken aus der Tür zu höhren ist. Dann das Fenster wieder hoch fahren und Knopf festhalten bis zum Klick. Diese Prozedur für jedes Fenster wiederholen.
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Standheizung in Passat 3BG einbauen Troubleshooting & Guides
No new posts Doku Passat MKB AVB, Kraftstoffverlust Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Komfortschließung Diesel Engine Technology
No new posts Passat 3B: Kat vom 110 PS TDI an den 115 PS PD TDI? Diesel Engine Technology
No new posts MFL Passat 3BG Electrical Systems, Vehicle Electronics, Multimedia
No new posts Log Passat v6 TDI Raw Upload
