VP44 fuel injector on Audi A6 AKN model drawing air, causing starting problems in the V6 engine (Solution)
georgmech
Post21-03-2010, 10:59    Subject: VP44 fuel injector on Audi A6 AKN model drawing air, causing starting problems in the V6 engine Quote
"Help! My VP44 injection pump on my Audi A6 2.5 TDI is drawing air. If the car sits for more than 5 hours, it won't start. There's no air in the clear fuel supply line, but when I use a vacuum pump on the return line, a lot of air comes out. After pumping about 5 times, the engine starts immediately without any problems. I've already disabled the fuel preheating, installed a new return valve, connected a direct hose from a canister, and even replaced the pump's shaft seal. The problem definitely comes from the ESP (Electronic Stability Program), but where?" I'm slowly running out of ideas.
Back to top Profile PM Email
Albrecht
Post21-03-2010, 11:25    Subject: VP44 fuel injector on Audi A6 AKN model drawing air, causing starting problems in the V6 engine Quote
O-ring, see exploded view diagram.
Edit Admin: Please ALWAYS pay attention to the copyrights of uploaded material!
Looking at the VP44 from the drive wheel, there is a fixing screw on the right-hand side, with a small retaining bracket underneath it. The O-ring, which is often hardened, is located on the screw and is in position 392. The Bosch part number is 1 460 225 083.
See:
http://eu-auto-2000.de/downloads/Ersatzteile%20%208778.pdf{MARKER}
01/01-08/08 Passat Variant 35i, 08/96, AFN, 94-283Tkm (5.Gg. defekt)
08/08-07/15 A6 (C5) Av. quattro 6-Gg., EZ 10/02, AKE 189-265Tkm (Kolbenriss)
07/15-09/17 A6 (C6) Av. qu. 6-Gg. 3.0 TDI, CDYC, EZ 05/11 180-210Tkm (verkauft)
08/17-11/17 A6 (C7) Av. qu 3.0 TDI comp.(leasing)
seit 2018 Skoda Roomster 1.6 TDI 5-Gg.
georgmech
Post21-03-2010, 11:28    Subject: VP44 fuel injector on Audi A6 AKN model drawing air, causing starting problems in the V6 engine Quote
Thank you very much, I will take a look. I also thought it might be somewhere in the suction side of the ESP. On the other hand, if the internal pump pressure is too high, diesel would leak out. I'll replace it right away.
georgmech
Post21-03-2010, 17:45    Subject: VP44 fuel injector on Audi A6 AKN model drawing air, causing starting problems in the V6 engine Quote
I just replaced the O-ring; it was really hard, like plastic. Tomorrow is the big day, but I have a good feeling about it.
georgmech
Post23-03-2010, 8:09    Subject: VP44 fuel injector on Audi A6 AKN model drawing air, causing starting problems in the V6 engine Quote
It's been doing this for two days now. When starting, it cranks a few times and then starts up very quickly. Thanks again for the tip. The mechanics quoted a price of €485 for the diagnosis, stating that the fuel injector control valve and the fuel pump in the ESP system were broken.
A new one would cost approximately €2500 icon_biggrin.gif including installation.
Ratings - VP44 fuel injector on Audi A6 AKN model drawing air, causing starting problems in the V6 engine
No new posts Starting problems and glow plug system issues in TDI engi... Technical Articles
No new posts Power steering is making a loud noise / sucking in air / ... General Tips
No new posts Golf3 pulls to the left (SOLVED) General Tips
No new posts Question regarding the VP44 and air in the intake Diesel Engine Technology
No new posts Astra G Diesel: Bleed VP44 Injection System Diesel Engine Technology
No new posts Audi 80 B4 pulls to the left Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Audi A6 Air in Fuel System: 2.5 TDI AKN Fix Diesel Engine Technology
