Key Signal Error Code (WFS)
Peter 2
Post21-02-2003, 12:31    Subject: Key Signal Error Code (WFS) Quote
I can't find any information about '01176 Key signal too small' in the error database.
My A3 wouldn't start. After reading and clearing the error codes, everything was okay again, but what was the cause?
The diagnostic tool isn't always available!
I need help.
Translated on 06-10-2026, 7:24.
Michael II
Post21-02-2003, 12:59    Subject: Key Signal Error Code (WFS) Quote
This can be caused by, for example:
- Faulty ignition switch rotor.
- Transition resistances in the cables are too high, possibly due to a loose connection.
Tschüss
Michael II
Translated on 06-10-2026, 7:25.
Peter 2
Post21-02-2003, 19:27    Subject: Key Signal Error Code (WFS) Quote
Thank you very much, Michael!
Unfortunately, it's difficult to address such a cause, especially since it's not currently occurring.
Is there a mobile diagnostic system that allows for reading and clearing error codes?
Golfmann
Post21-02-2003, 20:08    Subject: Key Signal Error Code (WFS) Quote
It could also be due to too many keys on the valve. This can also cause malfunctions.
Translated on 06-10-2026, 7:26.
Post21-02-2003, 23:15    Subject: Broken Car Key Fob? Get Replacement Now! Quote
Hi Michael,
For testing purposes, etc., I had a key made without a transponder.
When I turn the ignition on, the error message "Key signal too low" is also stored in the vehicle's fault memory system (WFS).
(actually, it should say "no key signal icon_twisted.gif")
Can these tiny transponders fail or malfunction in such a way that they no longer respond with sufficient signal strength icon_eek.gif icon_question.gif icon_question.gif?
Translated on 06-10-2026, 7:27.
Peter 2
Post22-02-2003, 10:44    Subject: Key Signal Error Code (WFS) Quote
If the reading coil doesn't receive a signal or receives a very weak signal, the cause is obvious. However, after clearing the error, the problem doesn't reappear, which is frustrating. And it's difficult to find the root cause without the error recurring.
Translated on 06-10-2026, 7:28.
marcello
Post22-02-2003, 12:14    Subject: Key Signal Error Code (WFS) Quote
In the early models of the Audi A4, some issues have been reported with the cable connecting the ignition coil to the immobilizer control unit.
I don't know how it is with the A3, but could you maybe check it? I've resoldered this on 5 Audis, and they all work perfectly.
Greetings from South Tyrol.
Back to top Profile PM Email
Michael II
Post22-02-2003, 20:39    Subject: Key Signal Error Code (WFS) Quote
Hello Ulf,
At university, I once conducted several measurement series using transponders (for logistics systems). Based on my experience, these devices almost never break.
Tschüss
Michael II
Translated on 06-10-2026, 7:29.
No new posts Error code P1351 General Tips
No new posts ESP function test, error code 01486 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error code 01276 - ABS hydraulic pump (V64) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error code Diesel Engine Technology
No new posts 2.5 TDI Error Codes: AAT & More Diesel Engine Technology
No new posts Error Code 575: Intake Manifold Pressure Problem Diesel Engine Technology
No new posts AFN Error Code 00550: Troubleshooting Guide Diesel Engine Technology
