Mercedes 124 Glow Plugs Replacement (1990)
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post17-02-2010, 20:14    Subject: Mercedes 124 Glow Plugs Replacement (1990) Quote
After checking the glow plug system, I now need to replace the ignition coil.
Is it better to completely remove the entire air filter housing to access the intake manifold from the right side for tightening?
Using a ratchet wrench with a double-offset of either 3/8 or 1/4 inch, pass it through the bridge.
or should the intake manifold be completely removed to access it?
Has anyone ever done this before, and do you have any tips?
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 01-10-2026, 5:15.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post17-02-2010, 21:02    Subject: Mercedes 124 Glow Plugs Replacement (1990) Quote
Translated on 01-10-2026, 5:16.
Post17-02-2010, 22:15    Subject: Mercedes 124 Glow Plugs Replacement (1990) Quote
Sure, dear TK!
Disassembling is often faster than struggling with it! Then you can easily access the spark plugs, and you can hold the ignition coil connector in place while loosening the spark plugs. Everything else is just unnecessary fiddling that wastes time.
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post18-02-2010, 9:38    Subject: Mercedes 124 Glow Plugs Replacement (1990) Quote
If you have the MB special tool to remove the crankshaft pulley, specifically that long socket with the tight cross joint and clamp inside, then you can skip removing the fan belt.
I would only remove the grounding bridge if the ESD devices are also being replaced.
If you only have a simple cross joint on the ratchet and it's wobbling around, I would remove the air filter, because otherwise certain spark plugs will drive you crazy. But even with the air filter removed, it's still a challenging job.
Translated on 01-10-2026, 5:17.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post18-02-2010, 14:03    Subject: Mercedes 124 Glow Plugs Replacement (1990) Quote
Thank you, I'll go ahead and put my knee joint in the rain so it becomes more difficult to move icon_lol.gif.
Translated on 01-10-2026, 5:18.
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post18-02-2010, 15:48    Subject: Mercedes 124 Glow Plugs Replacement (1990) Quote
reflexsilber met.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post18-02-2010, 17:28    Subject: Mercedes 124 Glow Plugs Replacement (1990) Quote
I know, it was a Joki icon_lol.gif.
Translated on 01-10-2026, 5:19.
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Spark plug firing order Technical Data
No new posts Glow Plug Module Replacement - Workshop Special Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Warmstart 5Zyl TDI (AEL) problematic Diesel Engine Technology
No new posts Chip Tuning 2.5L 5-Cylinder: Experiences? Diesel Engine Technology
No new posts Glow Plugs 1Z - Buy Online Now! Diesel Engine Technology
No new posts Spark Plug Fouling: Causes and Solutions Diesel Engine Technology
