Diagnostic Interface Issues: Troubleshooting Guide
vikinger
Post28-02-2003, 21:08    Subject: Diagnostic Interface Issues: Troubleshooting Guide Quote
My problem is that my VAG-Com interface only works when the engine is off. When the engine is running, it cannot establish a connection. However, I wanted to check the injection timing at the diesel pump and the torque, so the interface should also work with the engine running.
Does anyone happen to know the reason for this malfunction?
Translated on 25-07-2026, 16:23.
Post28-02-2003, 23:10    Subject: Diagnostic Interface Issues: Troubleshooting Guide Quote
Hi.
Apparently, unnecessary background software can overload the entire PC-based automotive system to such an extent that, when the engine is running and placing a higher processing load on the system, communication can be disrupted.
Sometimes the engine misfire only occurs at higher RPMs.
However, I also experienced problems related to voltage fluctuations with immature or improperly matched adapters: the extra 2 volts of onboard voltage while the engine was running caused communication failures.
What applies to you now: icon_question.gif icon_question.gif icon_question.gif icon_question.gif icon_question.gif
Translated on 25-07-2026, 16:24.
vikinger
Post01-03-2003, 11:40    Subject: Diagnostic Interface Issues: Troubleshooting Guide Quote
Hi Ulf,
Thank you for the tip. The car is a 2001 A4 with AKN engine, and the computer is an HP Omnibook with a Pentium 1000 processor. I bought the interface cheaply on eBay. I also suspect that the problem lies with the interface not working correctly.
Where can one get a decent KKL interface at the best price?
Translated on 25-07-2026, 16:25.
Post01-03-2003, 11:48    Subject: Diagnostic Interface Issues: Troubleshooting Guide Quote
vikinger wrote:
Where can one get a decent KKL interface at the lowest price?
If it's primarily about being affordable: Building it yourself icon_razz.gif icon_wink.gif.
You can find circuits and accompanying tips, for example, in the "Tips & Tricks" folder on Rainer's website, specifically under "Diagnostic Adapter."
Translated on 25-07-2026, 16:26.
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Sudden performance loss after restart, then okay again Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine starts, then immediately stalls. Model: ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Question about diagnostic interface On-Board Diagnostics (OBD)
No new posts mal wieder ein 1Z-Problem!!! Diesel Engine Technology
No new posts Problem mit OBD2 Diagnose Kit On-Board Diagnostics (OBD)
No new posts OBD2 Diagnostics for Non-Diagnostic CAN Bus On-Board Diagnostics (OBD)
