Engine Control Unit (ECU) Coding
marcello
Post22-02-2003, 15:08    Subject: Engine Control Unit (ECU) Coding Quote
Hello everyone.
I need to install a used engine control unit (ECU) into a Golf 4 TDI on Monday.
Install a Bj 98 Mot control unit (part number AHF). Can anyone tell me how to proceed with the coding process?
You need to proceed using the VAG 1552.
Greetings, Marcello.
Translated on 28-08-2026, 9:32.
Back to top Profile PM Email
Rudi
Post22-02-2003, 18:56    Subject: Engine Control Unit (ECU) Coding Quote
Hello Marcello,
What are the part numbers and software versions of the old and new control units?
Best regards, Rudi.
Translated on 28-08-2026, 9:33.
marcello
Post23-02-2003, 11:34    Subject: Engine Control Unit (ECU) Coding Quote
They are exactly the same!
Rudi
Post23-02-2003, 12:42    Subject: Engine Control Unit (ECU) Coding Quote
Hello Marcello,
Assuming the old control unit is 'original,' it should work as follows:
Replace the engine control unit (ECU) MSA15.
After installing a new engine control unit.
The following work steps must be carried out:
1. Perform the coding of the new engine control unit.
2. Adjust the immobilizer system to the engine control unit.
3. For vehicles equipped with a speed control system (recognizable by the switch on the steering column), this system must be activated in the engine control unit.
4. If necessary, check and clear the error memory.
Connect the VAG tester, either model 1551 or 1552.
· Insert the ignition key into position 2 (but do not start the engine).
· Input 01 (motor control)
· Input 07 (Code the control unit)
· Enter 00001 (automatic transmission) or 00002 (manual transmission).
Adjust the drive-away protection system to the engine control unit.
· Input 25 (immobilizer)
· Input 10 (Adjustment)
· Input 00 (Channel 0)
· Acknowledge the prompt 'Delete learning values' with the key 'Q'.
· Adjustments are completed by pressing the '->' button.
· Turn off the ignition.
Upon the next ignition start, the engine control unit (ECU) identification code is read by the immobilizer control unit.
Activate speed control system.
· Input 11 (Login procedure)
· Input 11463 (Deactivated 16167)
Best regards, Rudi.
Translated on 28-08-2026, 9:36.
marcello
Post24-02-2003, 0:20    Subject: Engine Control Unit (ECU) Coding Quote
Okay, Rudi, I'll try it tomorrow.
Thank you very much!
Translated on 28-08-2026, 9:39.
No new posts HEX-V2: Login failed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Coding Daytime Running Lights - How To Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Control Unit Errors: 2.5L V6 TDI (No Delete) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine control unit cannot be coded for manual transmission On-Board Diagnostics (OBD)
No new posts AI coding?! On-Board Diagnostics (OBD)
No new posts A3 8P SWRA Coding: How-To Guide On-Board Diagnostics (OBD)
No new posts Coding the second battery? Electrical Systems, Vehicle Electronics, Multimedia
