VW Caddy: Read Kilometer Stand from ECU
Go to page: 1, 2  Next
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Kruegerjean
Post28-01-2008, 18:49    Subject: VW Caddy: Read Kilometer Stand from ECU Quote
Unfortunately, I couldn't find a clear answer using the search function.
'I'm going to look at a VW Caddy for purchase for our company tomorrow. The car was first registered in 04/2004, it's a 2.0 SDI (new model), and according to the seller, it has 71,254 kilometers on the odometer. It's the second owner, and he has personally maintained the car during his ownership, so there's no current service history booklet.'
According to his statements, the clutch will soon need to be replaced (it seems to be slipping already), which makes me a bit suspicious considering the mileage. However, since the car was likely driven a lot in city traffic in Berlin, it would also be understandable.
My question is whether and how it is possible to professionally read the mileage from the engine control unit using Vag-Com 704.1.
I would be grateful for a prompt reply.
Jean.
Translated on 02-10-2026, 21:38.
Post28-01-2008, 20:06    Subject: VW Caddy: Read Kilometer Stand from ECU Quote
Hi Jean,
The engine control unit is likely an EDC16, and unfortunately, VAG-COM cannot be used to read the mileage from it (which I find very unfortunate).
Translated on 02-10-2026, 21:40.
mullemaus
Post29-01-2008, 19:25    Subject: VW Caddy: Read Kilometer Stand from ECU Quote
The mileage information is stored in the engine control unit (ECU) and the CAN gateway. Accessing both requires some effort. icon_wink.gif
3 Phasen Biber
Karma: +2 / -1   Thank you, like it!
2001 Volkswagen Golf
Post29-01-2008, 21:10    Subject: VW Caddy: Read Kilometer Stand from ECU Quote
Also, even if it's not ECD 15/16 compliant?
ehemals G4 ASZ, jetzt G4 ARL
Translated on 02-10-2026, 21:41.
mullemaus
Post29-01-2008, 21:15    Subject: VW Caddy: Read Kilometer Stand from ECU Quote
3 Phasen Biber
Post29-01-2008, 23:37    Subject: VW Caddy: Read Kilometer Stand from ECU Quote
I mean the naturally aspirated diesel engines!
"Gasoline cars don't have that feature, as far as I know, but maybe VW will eventually add it!"
mullemaus
Post30-01-2008, 19:38    Subject: VW Caddy: Read Kilometer Stand from ECU Quote
038906012AM 4203 does not have it. I checked it today. It is an ASY - SDI icon_wink.gif.
Klausilein
Post26-11-2009, 15:54    Subject: VW Caddy: Read Kilometer Stand from ECU Quote
Okay, I'm bringing this topic up again because I have a question about it. I'm planning to buy a Golf IV (PD variant with 100 or possibly 115 hp). I don't want to be misled by the mileage. Have I understood correctly that I can use VAGCOM to read the actual mileage from the engine control unit?
Nun ist die aktuelle Programmversion zum einen fĂŒr den Vierer wahrscheinlich(?) nicht unbedingt nötig und zum anderen kost das ja auch alles. Vielleicht lĂ€sst sich ja eine Ă€ltere (hierfĂŒr ausreichende) Programmversion auftreiben. Oder Is that nonsense?
For me, everything is still new territory icon_rolleyes.gif.
Are there any other software options that can do the same thing and that I can run on my laptop?
(It would be annoying to have to take the car to a VW dealership specifically to have it diagnosed.)
Sure, no problem!
Best regards, Klausi.
Translated on 02-10-2026, 21:42.
DieselBĂ€r30x
Avatar-DieselBĂ€r30x
Post26-11-2009, 16:23    Subject: VW Caddy: Read Kilometer Stand from ECU Quote
Hi Klausi!
Klausilein wrote:
... (it would be annoying to have to take the car separately to VW for a diagnostic scan)...
Why would that be a bad idea?
That would actually be a very good idea, because they can check in the database where and when the vehicle was serviced/repaired - ALONG WITH the corresponding mileage! icon_wink.gif
This way, you can even avoid the issue of selection bias and still be on the safe side.
Best regards from Munich!
1. S.verlÀngerung: Audi A4 Avant quattro, 1,9 TDi MKB: AFN, BJ98, Vollausstattung, +VP1L
Translated on 02-10-2026, 21:44.
Wiesel
Post26-11-2009, 21:35    Subject: VW Caddy: Read Kilometer Stand from ECU Quote
Besides that, the engine control unit (ECU) used is an EDC15, and there are quite a few "tools" available for it.
Whoever can manipulate the mileage displayed on the instrument cluster (KI) may also have the ability to modify the vehicle's mileage recording system (MSTG).
Micha
Translated on 02-10-2026, 21:45.
Klausilein
Post26-11-2009, 23:19    Subject: VW Caddy: Read Kilometer Stand from ECU Quote
Aha..
I used to think it was easy for kids today to change the mileage reading in the car's computer, but it seems that the MSG system will likely update it anyway.
I'm basically already ready to buy such a diagnostic program; it seems necessary for cars these days, judging by what people are reading here. "I'll do it myself" apparently isn't quite enough anymore. icon_sad.gif But well, it all sounds quite interesting.
Driving out to Hinterduckelsdorf on the weekend to look at a car is already a hassle, so it's annoying to then have to drag it somewhere else to another VW dealership because you suspect they're being dishonest. It would be much easier to just connect a diagnostic tool to check for any errors. You should also be able to see something about potential problems right away... (?)
It should be a cheap car, being sold privately.
Klausi.
Translated on 02-10-2026, 21:46.
Nico_ktm
Post27-01-2010, 12:05    Subject: VW Caddy: Read Kilometer Stand from ECU Quote
Is the mileage stored in the engine control unit (ECU) of an Audi A4 8E with a 2.5 TDI AKE engine?
Translated on 02-10-2026, 21:48.
vwSchrauber
Post27-01-2010, 12:15    Subject: VW Caddy: Read Kilometer Stand from ECU Quote
With VCDS, the updates are free, so forget about the older version. Anything you get there that's cheaper because it's older is definitely a cracked version icon_exclaim.gif.
mullemaus
Normally, yes. What is the part number of the control unit?
Translated on 02-10-2026, 21:49.
Nico_ktm
Post27-01-2010, 12:22    Subject: VW Caddy: Read Kilometer Stand from ECU Quote
I have no idea. I'll have to take a look. When reading the mileage, it says:
...something about being unavailable...
mullemaus
Post27-01-2010, 12:34    Subject: VW Caddy: Read Kilometer Stand from ECU Quote
Then it is not implemented or not configured. Therefore, the number is quite interesting icon_wink.gif.
No new posts VAG VIN Decoder: Model, Year & Location Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Reading Faults - VW Climatronic from Hella Troubleshooting & Guides
No new posts Error code Climatronic 3B, model year 1999, 2000 model Troubleshooting & Guides
No new posts After reading the error memory, the mileage suddenly incr... On-Board Diagnostics (OBD)
No new posts Do I Need a New Control Unit? On-Board Diagnostics (OBD)
No new posts Is the mileage stored in the control unit? (This is urgent.) On-Board Diagnostics (OBD)
No new posts Caddy 2.0 SDI: Faulty ECU? Diagnose & Repair. Diesel Engine Technology
