TDI Injector Adjustment: How-To Guide
Rahl
Post08-02-2010, 20:52    Subject: TDI Injector Adjustment: How-To Guide Quote
Hello, I want to check the injection timing on my car. However, I don't have a VAG-Com, but a Bosch tester. This tester can display the injection timing and fuel temperature, but in degrees (°), not with numerical values like the VAG-Com. I know the table from the forum that shows how to read the values, but it doesn't display degrees. Is there a way to convert these degree values? According to the diagram, the injection timing should be set to approximately 55° when the engine is at operating temperature.
According to my tester, I have 3.2° (I don't recall the diesel temperature).
The car is a VW Passat TDI 1.9L, manufactured in 1996.
Translated on 02-09-2026, 10:36.
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts ESP Adjustment: 1.6 TDI Guide Diesel Engine Technology
No new posts p-box einstellen Diesel Engine Technology
No new posts ESP Tuning for VW AAB Engine Diesel Engine Technology
No new posts Auxiliary Heater Settings: How to Adjust On-Board Diagnostics (OBD)
