BMW 330 Touring E46 - Can it be read out with VCDS? Parking assist
snowman24
Post20-03-2010, 15:19    Subject: BMW 330 Touring E46 - Can it be read out with VCDS? Parking assist Quote
Hello everyone,
My acquaintance's parking assist system has been malfunctioning for some time.
We would also like to read the error codes.
Does this work with the current version of VCDS?
I have the VCDS RKS 908.1 version here from this shop, along with the serial Hex-Can interface.
How can I read the error codes from a BMW?
Thank you in advance, and best regards.
Marcus.
Post20-03-2010, 15:36    Subject: Re: BMW 330 Touring E46 - Is it possible to read out data with VCDS? Parking assist Quote
No. Depending on the year of manufacture, the engine control unit (ECU) is compatible due to the standardized OBD (On-Board Diagnostics) system.
snowman24
Post20-03-2010, 15:48    Subject: BMW 330 Touring E46 - Can it be read out with VCDS? Parking assist Quote
Okay, and how can I read the error codes?
Is there software available for download for this, or is it only possible through BMW?
We came across the MSG (presumably referring to a vehicle's diagnostic system) while investigating, and in the process, we discovered a sporadic fault with the camshaft sensor.
Greetings.
Marcus.
Post20-03-2010, 16:06    Subject: BMW 330 Touring E46 - Can it be read out with VCDS? Parking assist Quote
Sorry, I don't know anything about BMW. It works normally with any universal diagnostic tool, such as Bosch KTS, Gutmann, etc. With VCDS, you can't stop, because it's also a VAG program. icon_wink.gif
No new posts Doku A6 4B, Einparkhilfe defekt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Parking Assist Failure: Audi A2 8Z0 MJ 2002 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 8E2/8E5 - Possible various error memory messages Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3B ABS FS reading not possible! On-Board Diagnostics (OBD)
No new posts What are some low-cost options for reading OBD data? On-Board Diagnostics (OBD)
No new posts Touran: Read DPF Ash Mass with VCDS (BLS) Diesel Engine Technology
No new posts Service reset not possible with VCDS RKS 21.3.0.0 On-Board Diagnostics (OBD)
