G3TDI Guest
25-02-2003, 7:32 Subject: Squeaky Brake Pedal: Causes and Fixes |
bei meinem 1Z quietscht das Bremspedal beim wenn ich den Fuss runternehme. Why?
Has anyone ever experienced this before?
It's been more than before since the last brake disc and pad replacement. It could also be a coincidence.
Jan.
Translated on 09-09-2026, 5:16.
Maik Guest
25-02-2003, 12:55 Subject: Squeaky Brake Pedal: Causes and Fixes |
Hi, I'm having the same problem, but with the clutch pedal.
Maik.
Michael II Profi-Schrauber
Joined: 04/12/2002 Posts: 1132 Karma: +3 / -0 Location: Stuttgart
25-02-2003, 13:25 Subject: Squeaky Brake Pedal: Causes and Fixes |
Jan6K also had problems with that before. Just do a search... Tschüss
Michael II
Translated on 09-09-2026, 5:17.
G3TDI Guest
25-02-2003, 13:35 Subject: Squeaky Brake Pedal: Causes and Fixes |
Okay, I'm going to try lubricating everything that moves  .
Outside, the noise is louder than inside, so the 'cause' must be located in the engine compartment  .
D. Guest
25-02-2003, 21:01 Subject: Squeaky Brake Pedal: Causes and Fixes |
Hello!
I've experienced similar problems with every car I've owned from the VAG group (AUDI 80, 1979; POLO, 1988; Golf III, 1992; Golf III, 1995), but only as the cars got older and accumulated more mileage.
According to information from 'Freundlicher,' the issue may be related to the return spring, which, however, cannot be lubricated.
With the POLO, the noise was surprisingly no longer noticeable when there was moisture or wetness, which, however, suggests that it can be eliminated.
Best regards, D.
Translated on 09-09-2026, 5:18.
G3TDI Guest
26-02-2003, 10:34 Subject: Squeaky Brake Pedal: Causes and Fixes |
'I took a closer look at the problem yesterday. The squealing is coming from the pedal and the rear brakes. There's a pin on the brake pedal. I applied grease to it as best I could (it's hard to reach), but it seems to have helped. I drove into town briefly yesterday and there was no more squealing from the pedal, but the rear brakes are still squealing. Do I need to disassemble the brake drums to fix that?'
Translated on 09-09-2026, 5:19.
Markus H. Guest
26-02-2003, 14:08 Subject: Squeaky Brake Pedal: Causes and Fixes |
Do you mean a squealing sound that occurs the moment you take your foot off the brake?
To fix this, the drum must indeed be opened.
My 'drum brake'-equipped Golf had that problem too.
Translated on 09-09-2026, 5:20.
26-02-2003, 17:57 Subject: Squeaky Brake Pedal: Causes and Fixes |
Hi everyone,
As Michael II already mentioned, I once had a similar issue with the clutch pedal. After several attempts (-> search function), the solution was to install a new bearing with some kind of Teflon material, which has been working perfectly without any squeaking ever since.
Jan. 1Z5 CFHF  / AHB H4D
Translated on 09-09-2026, 5:21.
G3TDI Guest
26-02-2003, 21:58 Subject: Squeaky Brake Pedal: Causes and Fixes |
Okay, so, after I figured out how to access the drum, I sprayed some special spray from ATU between the plates. Now everything is working perfectly again  .
Thanks again for the tips.
According to atu, this is a common VW problem. He should have told me that I don't have to remove the wheel to open the drum *grr* so I spent 2 hours doing that  .
Translated on 09-09-2026, 5:22.
Bertil Profi-Schrauber
27-02-2003, 7:32 Subject: Squeaky Brake Pedal: Causes and Fixes |
G3TDI wrote: | He could have told me that you don't have to remove the wheel to open the drum, but he didn't *grr* so I spent 2 hours doing it  | .
... did it take you two hours to unscrew the wheel?
Quote: |
According to atu, this is a common problem with VW vehicles.
/Turning on sarcasm/
Oh, that problem is completely unknown to me.
/s
.... My Jetta does that, my Golf2 did that, my father's Golf 3 did that, my wife's Polo did that, my 6N Polo and my 1Z also squeaked from the brake drum. Only my AXR doesn't do it... oh, I forgot, it has disc brakes all around  .
After hearing so many squeaking cars, you simply filter out that braking noise (which is something humans don't want to hear...). Gruß Bertil
Translated on 09-09-2026, 5:23.
G3TDI Guest
27-02-2003, 12:35 Subject: Squeaky Brake Pedal: Causes and Fixes |
It took 2 hours for everything altogether. Half an hour of that was spent driving to ATU to look again in the repair manual to see how to unlock it.
Someday, I should buy a book for myself.
Translated on 09-09-2026, 5:25.
27-02-2003, 13:37 Subject: Squeaky Brake Pedal: Causes and Fixes |
G3TDI wrote: | | It took 2 hours for everything altogether. Half an hour of that was spent driving to ATU to look again in the repair manual to see how to unlock it. |
Okay, I think I understand now.
By the way, I would always remove the wheel beforehand. A brake drum is much more difficult to handle without the rim, and you don't need that long to remove the four wheel bolts... Gruß Bertil
