25-02-2010, 7:11 Subject: Supply voltage for steering angle sensor G85: Ignition and constant plus? |
In my 2006 Ibiza 6L, the G85 receives voltage through both constant power and ignition.
I haven't yet measured the standby current using the "Dauerplus" fuse, but...
"That will likely be a few milliamperes."
"Does the ESP system cause any problems if I disconnect the battery for several weeks at a time to prevent it from being unnecessarily discharged?"
So, if I were to connect the constant positive terminal to the ignition instead (to protect the battery), what problems might arise?
Translated on 17-07-2026, 23:34.
Profile PM Garage |
25-02-2010, 8:29 Subject: Supply voltage for steering angle sensor G85: Ignition and constant plus? |
Sure, here's the translation:
"Are there a lot of errors occurring during the process of starting, igniting, shutting off, restarting, and steering?"
Translated on 17-07-2026, 23:36.
Profile PM Garage |
T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
25-02-2010, 12:38 Subject: Supply voltage for steering angle sensor G85: Ignition and constant plus? |
"Ulf, since your beloved Ibi is sitting in the garage with unnecessary comfort features, and after seeing your cold start video, is there a 230V outlet available? If so, you could use a battery maintainer like a CTEK to keep the battery healthy! I have something similar in my T3 when it's stored for the winter. Its two batteries have lasted through eight years now!"
NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Profile PM Email Garage |
25-02-2010, 12:52 Subject: Supply voltage for steering angle sensor G85: Ignition and constant plus? |
Quote: | | I saw your cold start video; is there a 230V outlet | ?
What is the part number for the AEG Vampyr  ?
Translated on 17-07-2026, 23:37.
Profile PM Garage |
25-02-2010, 14:00 Subject: Supply voltage for steering angle sensor G85: Ignition and constant plus? |
T3Surfer wrote: | | Ulf, since your beloved Ibi is sitting in the garage with unnecessary comfort features, and after seeing your cold start video, is there a 230V outlet? If so, you could use a charger, such as a Ctek, to "massage" the battery. | Before I regularly go through this process (and incur unnecessary electricity costs), I would rather just swap one fuse.
Therefore, my question here is about the consequences  .
Translated on 17-07-2026, 23:38.
Profile PM Garage |
25-02-2010, 19:13 Subject: Supply voltage for steering angle sensor G85: Ignition and constant plus? |
Quote: | Before I regularly go through this hassle (and incur unnecessary electricity costs), I would rather just replace one fuse.
Just try it out! Unfortunately, I don't know what the effects might be.
"Three weeks is a long time; it shouldn't really make a difference."
Translated on 17-07-2026, 23:39.
Bertil Profi-Schrauber
25-02-2010, 22:21 Subject: Re: Power supply for steering angle sensor G85: Ignition and constant voltage? |
ulf wrote: | ...
There's a good reason for that.
These are piezoelectric gyroscopic sensors. They have the unpleasant property of not performing well during "cold starts," which results in inaccurate readings.
If you can live with the fact that your ESP might not work correctly for a while, then there's nothing wrong with your plan. However, it is extremely dangerous in all cases.
The quiescent current for these components is in the microampere range. If this drains your battery too quickly, then it's probably time to replace it anyway.
Translated on 17-07-2026, 23:40.
26-02-2010, 6:34 Subject: Re: Power supply for steering angle sensor G85: Ignition and constant voltage? |
Bertil wrote: | | These are piezoelectric gyroscopes. They have the unpleasant property of not liking "cold starts" and therefore being inaccurate in those situations. | Ah, finally we're getting to the hard technical background  .
Quote: | | If you can live with the fact that your ESP might not function correctly for a while, then there's nothing to object to regarding your plan. | Ah yes.
Does the term " cold starts" not refer to "" only affecting " " precision, but not lifespan?
However, it is extremely dangerous in all cases Quote: | because, for example, the ESP could mistakenly detect a skidding vehicle due to premature activation (cold sensors) and then react accordingly?
How long (approximately) do the sensors take to start providing accurate data after a cold start?
| The quiescent current for the components is in the µA range. Quote: | . . . without any additional electronics being powered via the main power supply?
I'll definitely measure the amount of current flowing through the "Duration Plus" wire. |
Translated on 17-07-2026, 23:43.
Profile PM Garage |
goettmann Guest
26-02-2010, 10:55 Subject: Supply voltage for steering angle sensor G85: Ignition and constant plus? |
Hello Ulf,
I find it very amusing what you are interested in here and how you want to implement something. Without even considering the consequences this intervention will have for you and possibly innocent road users.
I'm sorry, but any interference with safety-critical components is where I draw the line.
Besides the subsequent cancellation of the vehicle registration ('ABE'), there's also the loss of insurance coverage. Given that this situation involves a risk to the general public combined with gross negligence, it already constitutes a criminal offense.
Despite that, here are some answers:
How long (roughly) do the sensors take to start providing accurate data after a cold start?
Depending on the environmental conditions, up to 60 minutes.
Does the term 'cold starts' not refer only to precision, but not to lifespan?
Both...and.
'One more question:'
Does your car have an alarm system?
If so, think about what the sensors might potentially be used for  .
Translated on 17-07-2026, 23:46.
matthiasTDI96 Profi-Schrauber
26-02-2010, 11:29 Subject: Supply voltage for steering angle sensor G85: Ignition and constant plus? |
goettmann wrote: |
Ulf doesn't have that, or rather, it refers to all the vehicle parts that need to be removed.
My Golf has been sitting in the underground garage all winter, with temperatures below freezing, for exactly 22 nights and 23 days without being used. It even has an alarm system. The battery is still the original one from 07/2002, and what can I say, it started up perfectly without any problems... not as fresh as on the first day, of course, but it was definitely enough to get it going. Unfortunately, I couldn't connect a trickle charger because there's no power outlet available, and I missed the opportunity to remove the battery.
So, it should definitely be possible, even with a relatively new car, to leave it unattended for three weeks without compromising any essential systems.
Or is this a preparation for your ultimate victory, which now also includes the expansion of ESP and ABS, because the mechanics involved certainly weigh 10 kg, the wiring harness is not insignificant, and then there are the sensors  .
Translated on 17-07-2026, 23:49.
26-02-2010, 11:30 Subject: Supply voltage for steering angle sensor G85: Ignition and constant plus? |
goettmann wrote: | I'm sorry, but any intervention in safety-critical components is where the fun really stops.
Besides the potential loss of the ABE (driving license), there's also the risk of losing insurance coverage. Given that this situation involves a danger to the public combined with gross negligence, it already constitutes a criminal offense.
Quote: | | How long (approximately) do the sensors take to provide correct data after a cold start? | Depending on the environmental conditions, up to 60 minutes. | It's good that you point out the background information.
"By the way, I find the purely technical implications of this to be quite bizarre."
For example, if jump-starting successfully revives a deeply discharged battery, the gyroscope sensors also undergo a cold start. If you then immediately drive off (as is common), the car would essentially be a rolling time bomb for up to an hour with a disabled Battery Management System (BMS).
However, the Ibiza owner's manual does not mention anything about this under either the "Jump Start" or "ESP" sections...
Quote: | Does your car have an alarm system?
If so, think about what the sensors might potentially be used for . | No, it does not have a remote control system.
Translated on 17-07-2026, 23:52.
Profile PM Garage |
I don't believe it's a good idea to take on unpredictable risks for the sake of a minimal (and likely immeasurable) increase in battery life, and I advise all readers against such modifications.
Translated on 17-07-2026, 23:54.
Profile PM WWW Garage |
goettmann Guest
26-02-2010, 11:45 Subject: Supply voltage for steering angle sensor G85: Ignition and constant plus? |
If you were to immediately drive off as usual, the car would then be a ticking time bomb for a maximum of one hour with an expired inspection sticker.
Without a valid ABE (approval document). This is accepted because...
But the Ibiza owner's manual doesn't mention anything like that, neither under 'Jump Start' nor under 'ESP.'
... you don't need a jump start every day.
Furthermore, the documentation (DFU) should state that a workshop must check the system for error entries.
It's worth noting that, depending on the specific ESP system and software used, it is even possible that the ESP warning light will remain illuminated for some time after such an incident (until the next restart).
Translated on 17-07-2026, 23:55.
26-02-2010, 12:07 Subject: Supply voltage for steering angle sensor G85: Ignition and constant plus? |
goettmann wrote: | | Furthermore, the DFU should state that a workshop must check the systems for error entries. | What is DFU?
Translated on 17-07-2026, 23:56.
Profile PM Garage |
goettmann Guest
26-02-2010, 13:06 Subject: Supply voltage for steering angle sensor G85: Ignition and constant plus? |
What is DFU?
DFU = IFU = User Manual.
'Direction for use' = 'Instructions for use' = 'Operating instructions'
Translated on 17-07-2026, 23:57.
26-02-2010, 13:39 Subject: Supply voltage for steering angle sensor G85: Ignition and constant plus? |
Without the G85 component, the servo will also fail.
At least the emech. in the G5 and 3C models do that.
"Ehydo" is likely available in Ibiza, but possibly also elsewhere.
Translated on 17-07-2026, 23:58.
Profile PM Garage |
