HEX-USB+CAN Adapter Firmware Update: Questions?
carstix
Post21-04-2010, 20:54    Subject: HEX-USB+CAN Adapter Firmware Update: Questions? Quote
Hopefully, I'm not already making a fool of myself with my first post... but I couldn't find the answer I was looking for through the search.
How do I update the firmware for the adapter mentioned above? From the Ross-Tech website, I understand that you need to register before you can access the update.
The registration form doesn't accept the "short serial number" that is printed on the adapter.
Is a firmware update possibly integrated into the VCDS software?
The adapter has been working fine so far, but I would still like to know...
Greetings.
Carsten.
Translated on 25-09-2026, 16:53.
Post22-04-2010, 8:44    Subject: HEX-USB+CAN Adapter Firmware Update: Questions? Quote
No, no faux pas. icon_smile.gif You don't need to register anywhere else, as you are already registered with me.
Or is a firmware update possibly integrated into the VCDS program?
Okay. If a firmware update is necessary, VCDS will indicate this, for example, by displaying a message after clicking the 'Test' button in the program settings.
Currently, for VCDS version 908.2, the firmware for your HEX-USB+CAN device is version 181.
Translated on 25-09-2026, 16:54.
No new posts Dimensions GT17/BV43 Turbocharger Adapter Technical Data
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Ulf's Adapter - Question about the trimmers in the circui... Diesel Engine Technology
No new posts VAGCOM Adapter: Questions and Answers Diesel Engine Technology
No new posts VCDS 22.10 Update & HEX-V2 Firmware Update On-Board Diagnostics (OBD)
No new posts VCDS Update, Firmware Update - Troubleshooting On-Board Diagnostics (OBD)
