Climatronic Diagnosis: Troubleshooting & Repair
markus78
Post01-03-2003, 10:21    Subject: Climatronic Diagnosis: Troubleshooting & Repair Quote
Hello everyone!
The engine temperature described in section 45 of this diagnostic mode: does this refer to the coolant temperature or the oil temperature? It would be very useful to know when the oil has reached its operating temperature.
best regards, markus
Translated on 17-10-2026, 9:56.
Manuel Thomas
Post01-03-2003, 21:20    Subject: Climatronic Diagnosis: Troubleshooting & Repair Quote
This is the coolant temperature reading from sensor G71. It's located on the cylinder head, directly next to the glow plug auxiliary heater.
Manuel.
Uwe
Post01-03-2003, 21:52    Subject: Climatronic Diagnosis: Troubleshooting & Repair Quote
Hi!
I suspect that this value is merely calculated for the climate control system. In my A3, manufactured in 1999, after turning on the ignition and the engine is off, the temperature reading increases to exactly 90 degrees.
It definitely isn't the oil temperature.
Uwe.
Kundenservice bedeutet bei Audi, die Kunden so schnell über den Tisch zu ziehen, daß sie die Reibungswärme als Nestwärme empfinden!
Translated on 17-10-2026, 9:57.
Manuel Thomas
Post01-03-2003, 22:25    Subject: Climatronic Diagnosis: Troubleshooting & Repair Quote
When the intake air temperature drops below 5 degrees Celsius, this glow plug heating system activates. That's why you're seeing an increase in the temperature reading.
Is that channel 48 on your A3, right?
Manuel.
Translated on 17-10-2026, 9:58.
Uwe
Post02-03-2003, 11:43    Subject: Climatronic Diagnosis: Troubleshooting & Repair Quote
Hi!
I tried it again this morning.
A3 AHF, ambient temperature 12 degrees, channel 51, temperature reading increasing.
A4 AJM, located next to it, temperature is not increasing!
What kind of glow plug heating system is this? Could something be heating up in my A3 even at higher outside temperatures?
Uwe
Manuel Thomas
Post02-03-2003, 12:38    Subject: Climatronic Diagnosis: Troubleshooting & Repair Quote
This glow plug heater is located exactly where the temperature sensor is also situated.
The temperature sensor G72 reports the temperature in the intake manifold to the control unit after the ignition is turned on. When a certain threshold (approximately 5 degrees Celsius) is reached, the glow plugs in the coolant are activated.
To prevent the battery from discharging, one, two, or all three glow plugs are activated, depending on the capacity of the three-phase generator. The three-phase generator is connected to the control unit via the DF terminal. When the engine is not running, only one glow plug is used for heating.
The auxiliary heater will be switched off when the coolant reaches a certain temperature. The rule is: the colder it is, the longer the coolant will be heated.
Manuel.
Translated on 17-10-2026, 10:00.
Uwe
Post03-03-2003, 21:49    Subject: Climatronic Diagnosis: Troubleshooting & Repair Quote
Hi Manuel!
You probably mean the glow plug heater, at least that's what I call it in my vocabulary. Sorry, the glow plug heater terminology confused me a bit.
Okay, I tried something: I kept the ignition on for 20 minutes without starting the engine. On channel 51 (engine temperature), the display slowly rises to 90 degrees and then stops exactly there, as if stuck. This display doesn't correspond to the analog coolant temperature gauge, which remains at the bottom. The ventilation fan tries to heat the interior and goes up about 7 levels. It's probably just calculating the value instead of actually measuring it...
Uwe.
Translated on 17-10-2026, 10:02.
No new posts Climatronic Error: Doku Sharan 7M8 Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error code Climatronic 3B, model year 1999, 2000 model Troubleshooting & Guides
No new posts Reading Faults - VW Climatronic from Hella Troubleshooting & Guides
No new posts Ibiza: Climatronic Diagnosis Mode Guide Transmission, Chassis, Body & Interior
No new posts Climatronic Error Code 04F7: Diagnosis & Troubleshooting On-Board Diagnostics (OBD)
No new posts Climatronic G3 TDI Transmission, Chassis, Body & Interior
No new posts Log Climatronic Upload
