Herbert Profi-Schrauber
15-04-2010, 8:43 Subject: Adjustment device for brake force regulator, Audi 80 B4 |
Audi specifies adjustment device 3284 for the rear axle brake force distribution system when it is being deactivated. Basically, it's a plate with two bolts that are inserted into two holes on the brake force regulator for adjustment.
The tool is easy to make if you know the distance and diameter of the bolts. Measuring the distance at the built-in regulator is somewhat inaccurate, and it assumes the original condition.
Perhaps one of you has the dimensions (and bolt diameters), or can measure them from an existing 3284?
Thank you very much in advance!
Okay, I understand. Please provide the German text you would like me to translate into English. I will only provide the translation.
wolfi_b Profi-Schrauber
19-04-2010, 6:58 Subject: Adjustment device for brake force regulator, Audi 80 B4 |
I also built a replica of that thing.
[img][/img]
Pin pitch (center-to-center): 50mm; Pin diameter: 5mm.http://img64.exs.cx/img64/2637/lehre32842tw.jpg{MARKER} 1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
19-04-2010, 7:04 Subject: Adjustment device for brake force regulator, Audi 80 B4 |
Thank you! That's exactly what I wanted.
Herbert. Horch A4 8K CJCD
