Document: Sharan, Auxiliary Water Heating System Not Working (Solution)
Michael II
Post05-03-2003, 11:40    Subject: Document: Sharan, Auxiliary Water Heating System Not Working Quote
Due to overheating, the auxiliary water heating system is switched off shortly after starting.
Up to VIN:
7MZ 1V 051819
Cause:
The reason for the overheating is a incorrectly installed water hose in the cooling circuit. A cooling water hose with a thermostat was installed from the first heat exchanger to the auxiliary water heating system. This coolant hose may only be installed in vehicles without an auxiliary water heating system.
In vehicles equipped with an auxiliary water heating system, there is no thermostat in the coolant hose from the first heat exchanger to the auxiliary water heating system.
Solution:
Check if the correct coolant hose without a thermostat has been installed, if not, replace the coolant hose.
Tschüss
Michael II
Ratings - Document: Sharan, Auxiliary Water Heating System Not Working
No new posts Document A6 4B, valid until 03/2001, central locking, sin... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Door Lock Malfunction: A6 4B Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Headlight Failure: A4 8D Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Reverse Gear Sharan TDI Automatic Not Working Transmission, Chassis, Body & Interior
No new posts ASR Not Working: Troubleshooting & Fixes Transmission, Chassis, Body & Interior
No new posts ESP Failure: Causes and Solutions On-Board Diagnostics (OBD)
No new posts Fresh air blowers without function On-Board Diagnostics (OBD)
