Documentary: Programming VW car keys from 1998 onwards (Solution)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
Octavia_4x4
CAN Support
Post29-05-2010, 10:44    Subject: Documentary: Programming VW car keys from 1998 onwards Quote
Here's the documentation on how to program radio keys, whether they are standard keys or flip keys, for various VAG models, such as:
VW:
Please provide the text you would like me to translate from German to English. Volkswagen Golf IV.
Please provide the text you would like me to translate from German to English. Bora.
Please provide the text you would like me to translate from German to English. Passat 3B/G
Please provide the text you would like me to translate from German to English. Beetle.
Please provide the text you would like me to translate from German to English. Polo 9N
SEAT:
Please provide the text you would like me to translate from German to English. Ibiza 6L
Please provide the text you would like me to translate from German to English. Leon 1M
Please provide the text you would like me to translate from German to English. Toledo 1M
SKODA:
Please provide the text you would like me to translate from German to English. Octavia 1 and 2.
Please provide the text you would like me to translate from German to English. Fabia 1 and 2.
Please provide the text you would like me to translate from German to English. Superb 1
Problem:
Please provide the text you would like me to translate from German to English. The radio is not working because either a) a new radio transmitter was purchased, or b) the batteries have been changed.
Please provide the text you would like me to translate from German to English. The owner's manual is sometimes inaccurate, for example, it doesn't accurately describe how to do certain things for my Octavia.
Instructions:
(1) Insert a mechanically compatible spare key (not the one that needs to be reprogrammed) into the ignition switch and turn the ignition on.
(2) Manually lock the car door from the outside (using the key, not the remote).
(3) Then, immediately press one key (regardless of whether it's the on or off key) on the radio key you want to learn, wait one second, and press the key again.
(4) Manually unlock the vehicle and turn off the ignition.
(5) Test the newly learned key. The function only works after the ignition is turned off.
Note: Previously paired keys do not need to be re-paired; they will remain connected. When replacing all keys, it may be necessary to reprogram the immobilizer system.
Ratings - Documentary: Programming VW car keys from 1998 onwards
No new posts T5 Model 2014 Key Programming via VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A4 8D bis KW 45/1998, Kühlmittelverlust Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Probleme mit Airbagsensoren MJ 1998 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Funkschlüssel anlernen über Zentralsteuergerät On-Board Diagnostics (OBD)
No new posts Fehler in "Doku Leistung der AFN-Motoren, MJ 1998" Diesel Engine Technology
No new posts neuer Funkschlüssel On-Board Diagnostics (OBD)
No new posts Funkschlüssel Anlernen:Funk ok aber WFS blockiert beim S... On-Board Diagnostics (OBD)
