Spark plug difference Audi 3.0 TDI 059 963 319E vs. J
ch914er
Karma: +5 / -2   Thank you, like it!
2005 Audi A4
Post16-12-2016, 20:03    Subject: Spark plug difference Audi 3.0 TDI 059 963 319E vs. J Quote
Good evening.
I'm having a problem.
I was just about to change the spark plugs and I bought some new BERU ones, which have the following number on them:
059 963 319J
I took out an old one, but the glow stick is shorter icon_eek.gif.
The following number is on the old 059 963 319E.
Can I install them now, or will the pistons hit something at the end? icon_confused.gif
According to the eBay seller, they are all the same.
03L 963 319
03L 963 319A
059 963 319
059 963 319C
059 963 319E
059 963 319F
059 963 319J
059 963 319M
Confused greetings from the garage.
Chris.
 File size:  2.32 MB
 Viewed:  1721 times
Translated on 19-07-2026, 1:05.
Post16-12-2016, 23:12    Subject: Spark plug difference Audi 3.0 TDI 059 963 319E vs. J Quote
According to Beru http://beru.federalmogul.com/de/e-catalogue/part-number,
Are the spark plugs identical and compatible with the GE115?
Assuming they are genuine replacement parts and not fake, it should fit. icon_smile.gif
Translated on 19-07-2026, 1:08.
ch914er
2005 Audi A4
Post17-12-2016, 0:30    Subject: Spark plug difference Audi 3.0 TDI 059 963 319E vs. J Quote
Thank you very much!
dieselschrauber likes this.
Post18-12-2016, 20:48    Subject: Spark plug difference Audi 3.0 TDI 059 963 319E vs. J Quote
It still might not hurt to manually rotate the engine once after screwing in the new glow plugs. icon_wink.gif
No new posts Spark plug firing order Technical Data
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Glow Plug Module Replacement - Workshop Special Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Turbochargers: Differences Explained Diesel Engine Technology
No new posts Rear brake calipers, difference? Audi A3 8L, year of manu... Transmission, Chassis, Body & Interior
No new posts Wheel offset problem: ET 45 versus ET 33 Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Fuel Injector Difference: T4 151PS vs. Audi AEL 140PS Diesel Engine Technology
