twix_72
2003 Audi A8 Premium Support
22-06-2010, 22:03 Subject: Alarm Source Meaning A8 4E |
Hello everyone.
"On my Audi A8 4E 4.2 with 335 horsepower, manufactured in May 2003, I've been experiencing the following problem for a few months."
My alarm system has been triggered too often without a valid reason, and it seems to happen more frequently when the outside temperature is higher.
In the last four trigger fields, all four display "10???"
Can someone tell me what alarm source 10 means?
Translated on 11-08-2026, 7:36.
Profile PM Garage |
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2403 Karma: +441 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
22-06-2010, 22:22 Subject: Alarm Source Meaning A8 4E |
Please set the fault memory log. The control unit number will be included in the log, and I am confident that someone can help you with that information.
Translated on 11-08-2026, 7:37.
Profile PM Garage |
22-06-2010, 22:27 Subject: Alarm Source Meaning A8 4E |
Normally, the label file specifies which number corresponds to what. MfG. Michael
Translated on 11-08-2026, 7:38.
Profile PM Garage |
twix_72
22-06-2010, 22:35 Subject: Alarm Source Meaning A8 4E |
Here's my error log.
Tuesday, June 15, 2010, 6:20:28 PM: 27057
VCDS version: RKS 908.2
Data as of: 20100327
Vehicle type: 4E0
Scan: 01 02 03 05 06 07 08 09 15 16 17 19 1E 25 34 36 37 38 42 46
47 4F 52 53 55 56 57 61 62 65 67 72 76 77
Vehicle Identification Number (VIN): WAUZZZ4E93N009033. Mileage: 129,670 km.
00-Steering angle sensor -- Status: OK 0000
01-Motor -- Status: OK 0000
02-Gearbox -- Status: OK 0000
03-Brakes -- Status: OK 0000
05-Access/Startup Report -- Status: OK 0000
Front passenger seat adjustment - Status: OK 0000
07-Display/Control Unit -- Status: OK 0000
08-Climate Control/Heating -- Status: OK 0000
09-Onboard network -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-inch steering wheel -- Status: OK 0000
17-in-1 instrument -- Status: OK 0000
19-CAN Gateway -- Status: Error 0010.
1E-Media Player 2 -- Status: OK 0000
Immobilizer system -- Status: OK 0000
34-Level regulation -- Status: OK 0000
36-seat adjustable passenger seat -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof electronics -- Status: OK 0000
42-Door Electric Driver -- Status: OK 0000
46-Comfort System -- Status: Error 0010.
47-Sound System -- Status: OK 0000
4F-Bus Network 2 -- Status: OK 0000
52-door electric passenger side door - Status: OK 0000.
53-Parking brake -- Status: OK 0000
55-Adjustable beam angle. -- Status: unreachable 1100.
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
61-Battery regulation -- Status: OK 0000
62 - Door, electric, left and right -- Status: OK 0000
Tire pressure -- Status: Error 0010.
Voice control -- Status: OK 0000
Door 72, electric hinge, right side - Status: OK 0000.
76-Parking Assist -- Status: OK 0000
77-Phone -- Status: OK 0000
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den Bäumen. Ein leichter Wind weht durch das Gras. Es ist ein wunderschöner Tag."
"The sun is shining brightly and warmly. The birds are chirping happily in the trees. A gentle breeze is blowing through the grass. It's a beautiful day."
Address 01: Engine; Label file: 077-910-560-BFM.lbl.
Part number SW: 4E0 910 560 E, HW: 4E0 907 560.
Component: 4.2L V8/5V G 0010
Revision: 00000000 Serial Number: AUX3Z0C1110716
Encoding: 0011773
Operating number: WSC 02313 785 00200
No errors found.
Readiness: 0110 1101
Address 02: Transmission Label file: 09E-927-156.lbl
Part number SW: 4E0 910 156 E, HW: 09E 927 156 A.
Part number: AG6 09E 4.2L5V RdW 0110.
Revision: 00000001 Serial Number: 0010711
Encoding: 0000001
Operating number: WSC 00260 223 87332
No errors found.
Address 03: Brakes Label file: RKS\4E0-910-517.lbl
Part number SW: 4E0 910 517 A, HW: 4E0 614 517 E.
Part number: ESP 5.7 all-wheel drive H29 0420.
Encoding: 0008597
Operating number: WSC 02313 000 00000
No errors found.
Address 05: Access/Startup Authorization. Label file: RKS\4E0-910-131.lbl
Part number SW: 4E0 910 131, HW: 4E0 909 131.
Component: FBS AUDID3 H02 0110
Revision: 01103502 Serial Number: AUX3Z0C1110716
Coding: 0262144
Operating number: WSC 02311 785 00200
Part number: XXXXXXXXXXX
Component: Low Voltage (ELV) XXXX
No errors found.
Address 06: Front Seat Adjustment
File label: None
Part number SW: 4E0 910 760 C, HW: 4E0 959 760.
Part: Seat Memory Module BFS H06 0050.
Revision: 00000000 Serial Number: 5DS 008 795-03
Encoding: 4063328
No errors found.
Address 07: Quantity/Control Unit
Label file: RKS\4E0-910-7xx-07.lbl
Part number SW: 4E0 910 769 Q, HW: 4E0 035 729 A.
Component: Interface box H43 5570.
Revision: 00000000 Serial Number: 300CH037517376
Encoding: 0030001
Operating number: WSC 00000 000 08192
Part number: 4E0 910 609.
Component: Control Unit MMI H41 0010.
No errors found.
Address 08: Climate Control/Heating Label file: RKS\4E0-910-043.lbl
Part number SW: 4E0 910 043, HW: 4E0 820 043 A.
Component: CLIMATE CONTROL UNIT 015 0240
Revision: 00000014 Serial number: 00000000014042
Coding: 0004289
No errors found.
Address 09: Body Control Module
Label file: 4E0-910-279.lbl
Part number SW: 4E0 910 279 Q, HW: 4E0 907 279 Q.
Component: ILM Driver H15 0230
Encoding: 0131121
Part number: 4E1 910 113.
Part number: Wiper blade WWS D3 H30 0320.
Encoding: 00000030
No errors found.
Address 15: Airbag
Label file: RKS\4E0-910-655-84.lbl
Part number SW: 4E0 910 655, HW: 4E0 959 655.
Part: Airbag 8.4E+ H08 0840
Encoding: 0430707
No errors found.
Address 16: Steering wheel
Label file: RKS\4E0-910-549.lbl
Part number SW: 4E0 910 549, HW: 4E0 953 549.
Component: Steering column module H09 0030.
Encoding: 0012141
Component: Steering wheel module H02 0050.
No errors found.
Address 17: Combination Instrument
Label file: RKS\4E0-910-xxx-17.lbl
Part number SW: 4E0 910 900, HW: 4E0 920 900 E.
Bauteil: KOMBIINSTR. VDO H42 0060
Revision: D07 Serial Number: AUDID3C3014157
Encoding: 0000123
Operating number: WSC 78384 668 1502023
No errors found.
Address 19: CAN Gateway
Label file: RKS\4E0-910-468.lbl
Part number SW: 4E0 910 468, HW: 4E0 907 468 A.
Component: Gateway H06 0050
Revision: 06 Serial number: 10003033220232
Encoding: FCFE7BDD2B7504
Operating number: WSC 00057 223 00316
No errors found.
Address 1E: Media Player 2
Label file: RKS\4E0-910-111.lbl
Part number SW: 4E0 910 111 F, HW: 4E0 035 111.
Component: CD Changer H43 0470
Serial number: AUZ5ZBC1012226
Operating Number: WSC 00000 000 00000
No errors found.
Address 25: Immobilizer
Coding: 0262144
XXXXXXXXXXX ELV XXXX
No errors found.
Address 34: Level Control
Label file: RKS\4E0-910-553.lbl
Part number SW: 4E0 910 553 D, HW: 4E0 907 553 D.
Component: AIR FILTER - CDC H04 6230
Encoding: 0015500
No errors found.
Address 36: Seat adjustment for driver. Label file: None.
Component: Seat Memory Module FS H06 0050.
Encoding: 4063330
No errors found.
Address 37: Navigation
Label file: RKS\4E0-910-88x-37.lbl
Part number SW: 4E0 910 888 P, HW: 4E0 919 887 C.
Component: MNS ECE H41 1060
Revision: 00000000 Serial Number: 305D8037532004
No errors found.
Address 38: Roof electronics
Label file: RKS\4E0-910-135.lbl
Part number SW: 4E0 910 135 A, HW: 4E0 907 135 A.
Component: Roof joint D3 H01 0080.
Serial number: 00000305500206
Encoding: 0003734
Operating number: WSC 00645 223 11046
No errors found.
Address 42: Door electrical driver
Label file: RKS\4E1-910-802.lbl
Part number SW: 4E1 910 802, HW: 4E1 959 801.
Component: Door control unit. FS BRM004 0080
Encoding: 0028452
No errors found.
Address 46: Comfort System
Label file: 4E0-910-289.lbl
Part number SW: 4E0 910 289 A, HW: 4E0 907 289.
Component: Comfort Device H03 0030.
Revision: 00300003 Serial Number: W040303310143
Coding: 0004728
Part number: 4E0 910 853.
Part: Rear lid / Trunk lid
H06 0060
Part number: 4E0 907 719.
Component: Tilt sensor H02 0020.
"One error found:"
01134 - Siren (H12)
004 - No signal/communication.
Environmental conditions:
Error status: 01100100
Error priority: 3
Error frequency: 6.
Lost Count: 132
Mileage: 129,527 km
Time: 0.
Date: 2010.06.08
Time: 19:09:43
Address 47: Soundsystem Label file: 4E0-910-223.lbl
Part number SW: 4E0 910 223 P, HW: 4E0 035 223 A.
Component: DSP Amplifier - High, Part Number H12 0460.
Revision: PROD_01O Serial Number: 00000000059218
Encoding: 0000026
No errors found.
Address 4F: Body Control Module 2
Label file: RKS\4E0-910-280.lbl
Part number SW: 4E0 910 280, HW: 4E0 907 280 A.
Part: Passenger-side ILM (Interior Light Module) H06 0060
Revision: Version
Serial number: 00000000012686
Encoding: 0010101
No errors found.
Address 52: Door electric, passenger side.
Part number SW: 4E1 910 802, HW: 4E1 959 802.
Component: Door control unit. BF BRM004 0080
Encoding: 0028452
No errors found.
Address 53: Parking brake
Label file: RKS\4E0-910-801.lbl
Part number SW: 4E0 910 801 A, HW: 4E0 907 801.
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Encoding: 0000531
No errors found.
Address 55: Headlight range control.
unavailable
Address 56: Radio
Label file: RKS\4E0-910-541.lbl
Part number SW: 4E0 910 541 T, HW: 4E0 035 541.
Component: TUNER EU/US/RDW H41 0630
Revision: 00000000 Serial Number: 304DL037521767
Encoding: 0000001
No errors found.
Address 57: TV Tuner Label file: RKS\4E0-910-146.lbl
Part number SW: 4E0 910 146 G, HW: 4E0 919 146.
Component: Analog TV Tuner H11 0300.
Revision: 00000093 Serial Number: 00000000000000
Encoding: 0001001
No errors found.
Address 61: Battery Management
Label file: RKS\4E0-910-181.lbl
Part number SW: 4E0 910 181 B, HW: 4E0 915 181.
Component: ENERGY MANAGER H02 0240.
Revision: 00000000 Serial Number: 00000000004025
Part number: 000 915 105 AK
Component: from VA0 1508221138
Encoding: 303030393135313035414B56413031353038323231313338
No errors found.
Address 62: Door electrics, left/right. Label file: RKS\4E0-910-802.lbl
Part number SW: 4E0 910 802, HW: 4E0 959 801 A.
Component: Door control unit. HL BRM004 0080
Encoding: 0028452
No errors found.
Address 65: Tire pressure
Label file: 4E0-910-273.lbl
Part number SW: 4E0 910 273, HW: 4E0 907 273.
Component: Tire Pressure Sensor 2 H01 0210
Encoding: 0212127
"One error found:"
01477 - System shut down.
text
000 - -
Error status: 01100000
Error priority: 4.
Error frequency: 1.
Lost Count: 132
Mileage: 129,670 km
Time: 0.
Date: 2010.06.15
Time: 18:19:07
Speed: 0.0 km/h
Temperature: 22.0°C
Error code: 0
recognized
recognized
recognized
recognized
Address 67: Voice Control
Label file: RKS\4E0-910-75x-67.lbl
Part number SW: 4E0 910 754 R, HW: 4E0 035 753.
Component: SDS 3500 DE H42 0630
Revision: 00000000 Serial Number: 00000303260035
Operating number: WSC 12336 024 394758
No errors found.
Address 72: Door electric strike, right side.
Part number SW: 4E0 910 802, HW: 4E0 959 802 A.
Component: Door control unit. HR BRM004 0080.
Encoding: 0028452
No errors found.
Address 76: Parking Assist
Label file: RKS\4E0-910-283.lbl
Part number SW: 4E0 910 283, HW: 4E0 919 283 A.
Component: Parking Assist System, 8-Channel, Part Number H07 0030.
Encoding: 0001008
No errors found.
Address 77: Telephone
Label file: 4E0-910-333.lbl
Part number SW: 4E0 910 333 F, HW: 4E0 862 333 C.
Component: EU TELEPHONE MODULE 0770
Revision: 00000003 Serial Number: T2AUDX0307H6Y5
Encoding: 0000004
No errors found.
"End"
Translated on 11-08-2026, 8:28.
Profile PM Garage |
Joined: 04/12/2002 Posts: 18117 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
23-06-2010, 7:49 Subject: Alarm Source Meaning A8 4E |
Take a look at measurement block 16 from the comfort control unit (address 46) using VCDS.
Quote: | 016,0,Alarm Sources.
; 0 = Door contact for the driver's door; 1 = Door contact for the passenger door.
; 2 = Door contact, rear left.
; 3 = Door contact, rear right.
4 = Engine Hood Contact
; 5 = Rear Lid Contact
; 6 = Terminal 15
; 7 = Interior Monitoring
; 8 = Non-Authorized Key (Thatcham)
; 9 = Backup horn (wire monitoring).
10 = Inclination Sensor
11 = Door Control Module, Driver's Side: Not connected to the data bus.
; 12 = Door Control Module, Passenger Side: Not connected to the data bus.
; 13 = Door Control Module Rear Left: Not connected to the data bus.
; 14 = Door Control Module Rear Right: Not connected to the data bus.
016,1,Last,Alarm Source
016, 2, 2nd Last, Alarm Source
016, 3, 3rd Place, Alarm Source.
016,4,4th Last,Alarm Source |
Translated on 11-08-2026, 8:30.
Profile PM WWW Garage |
twix_72
23-06-2010, 17:13 Subject: Alarm Source Meaning A8 4E |
Rainer K. wrote: | Hello,
; 6 = Terminal 15
; 10 = Inclination Sensor
11 = Door Control Module, Driver's Side: Not connected to data bus.
Best regards, Rainer |
Thank you all.
I consistently find the value "10" in measurement block 16, and now I see that it's a tilt sensor.
"One more question: Is it possible to test this tilt sensor, perhaps adjust it, or is it simply broken?"
Translated on 11-08-2026, 8:34.
Profile PM Garage |
23-06-2010, 17:25 Subject: Alarm Source Meaning A8 4E |
You can check if it's loose. The current values should be visible in another measurement block. Simply click on the blue label name in the measurement blocks located at the top left.
Translated on 11-08-2026, 8:38.
twix_72
23-06-2010, 20:08 Subject: Alarm Source Meaning A8 4E |
Hello Rainer,
It's not loose.
I just looked at the "Inclination Sensor" settings, and here are the values that can be adjusted:
200 = 0°.
180 degrees equals 1 radian.
160 = 2°
140 = 3°
120 degrees equals 4 radians.
100 = 5°
What do the degree (° ) numbers mean? I suspect it refers to sensitivity... anyway, mine was set to 200, and I've now changed it to 120, let's see what happens.
Thank you and best regards.
Peter.
Translated on 11-08-2026, 8:41.
Profile PM Garage |
23-06-2010, 22:42 Subject: Alarm Source Meaning A8 4E |
twix_72 wrote: | | What do the degree (°) numbers mean? I suspect it refers to sensitivity... |
In my label file, it is described as "Alarm Threshold." Additionally, the percentages are listed as 0.x degrees instead of just x degrees.
Here's the translation:
"Percentages should also be provided (100% at 0°, 50% at 0.5°)."
Your adaptation should be in the right direction.
Sure.
Here is the translation of the text from German to English:
"Guste" means "gust" in English. It can also be used as a verb, meaning "to gust."
Translated on 11-08-2026, 8:44.
Profile PM Garage |
