Windshield wiper switch, intermittent function, defective
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
hkss
Avatar-hkss
Karma: +13 / -0   Thank you, like it!
2017 Skoda Yeti
Post01-04-2011, 8:04    Subject: Windshield wiper switch, intermittent function, defective Quote
For the past year, the following error has repeatedly appeared in the log:
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den Bäumen. Ein leichter Wind weht durch das Gras. Es ist ein perfekter Tag für einen Spaziergang."
Address 16: Steering wheel
Label file: RKS\1K0-953-549-MY8.lbl
Part number SW: 1K0 953 549 AQ, Hardware number: 1K0 953 549 AQ.
Component: J0527 036 0070
Encoding: 0012042
Operating number: WSC 32573 146 95222
VCID: 812652A0A18F
Part number: XXXXXXXXXXX
Component: E0221 002 0010
"One error found:"
00888 - Wiper switch for intermittent operation (E22).
014 - defective
Deleting it doesn't do anything; it reappears immediately.
A genuine fault in the windshield wiper switch or intermittent function.
I can't find any issues - everything is working perfectly.
When I search for the error on Google, I only find another forum.
which states that both the switch and the module have been optimized in this regard, and that you should replace the switch first, then the steering column module.
Do you agree?
I still have a warranty or good chances of getting it fixed under goodwill, and I should probably have the workshop take care of it – or do you have any other ideas?
I'm not a big fan of taking cars to the workshop – often, it doesn't actually make the car any "better."
Translated on 20-07-2026, 2:35.
hkss
Avatar-hkss
2017 Skoda Yeti
Post20-04-2011, 20:33    Subject: Windshield wiper switch, intermittent function, defective Quote
Resolution:
First, the interval timer was replaced, but it didn't work.
Then the steering column module was replaced, and the old error (as described in the original post) disappeared.
But – there were now two new errors.
I was told at the workshop that these phantom error entries cannot be removed.
Then, thanks to a tip from another forum, I changed the coding on the new steering column module – and hooray, no more errors!
Here is the "technical explanation":
Wednesday, April 20, 2011, Time: 11:07 AM.
VCDS version: RKS 10.6.3
Data as of: 20110306.
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den Bäumen. Ein leichter Wind weht durch das Gras. Es ist ein wunderschöner Tag."
The sun is shining brightly and warmly. The birds are chirping happily in the trees. A gentle breeze is blowing through the grass. It's a beautiful day.
Vehicle type: 1K0
Scan: 16
Vehicle Identification Number (VIN): WVWZZZ1KZ8M320904 Mileage: 40,450 km
16-inch steering wheel -- Status: Error 0010.
The sun is shining brightly and warmly. The birds are chirping cheerfully in the trees. A gentle breeze is blowing through the grass. It's a beautiful day.
Part number SW: 1K0 953 549 BK, Hardware: 1K0 953 549 BK.
Component: J0527 051 0101
Coding: 0012122
Operating number: WSC 64319 136 186795.
VCID: 7CD8A354466D
"2 errors found:"
01749 - Switch for Tiptronic control on the steering wheel; down (E439).
010 - Interruption/Short circuit after positive terminal.
01748 - Switch for Tiptronic control on the steering wheel; up position (E438).
"End"
"Der schnelle braune Fuchs springt über den faulen Hund."
Wednesday, April 20, 2011, Time: 7:24 PM.
Vehicle type: 1K0
Scan: 16
Vehicle Identification Number (VIN): WVWZZZ1KZ8M320904 Mileage: 40,540 km
16-inch steering wheel -- Status: OK 0000
Coding: 0012022
VCID: 7CD8A354466D
No errors found.
End.
Translated on 20-07-2026, 2:44.
DieselBär30x
Avatar-DieselBär30x
Post20-04-2011, 21:38    Subject: Windshield wiper switch, intermittent function, defective Quote
Thanks for the interesting feedback!
"Please provide me with the question you would like me to answer."
Could the transmission be operated flawlessly via the steering wheel controls, despite the error message?
"...and what exactly did you change from 1 to 0?"
Best regards from Munich!
Translated on 20-07-2026, 2:52.
hkss
Avatar-hkss
2017 Skoda Yeti
Post21-04-2011, 8:25    Subject: Windshield wiper switch, intermittent function, defective Quote
Could the transmission be operated flawlessly via the steering wheel, despite the error message?
So, I actually don't have a steering wheel shifter.
At the workshop, I was told that the multifunction buttons on the steering wheel are called that.
even if they are the volume up/down, mute, or phone buttons.
And these buttons worked perfectly.
You can see what I have re-encoded above in the two logs: 1. Before, 2. After.
Specifically, the encoding "0012122" has been changed to "0012022".
I need to look into what the transition from 0 to 1 actually means.
I believe VCDS displays a list of options when you press the coding button. (Okay, if your question was a subtle hint that I did something – modified some settings – that I didn't fully understand beforehand, then you're right. I'll remember that and be more careful about what I do in the future. This time, it worked out fine.) icon_smile.gif
Best regards, HubärTUS icon_smile.gif.
Translated on 20-07-2026, 2:54.
No new posts VW T4 AHY: Defective Auxiliary Heater / Parking Heater Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts C4 AEL Coolant Temp Display Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Parking Assist Fault: Audi A6 (4B) Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MFA malfunction On-Board Diagnostics (OBD)
No new posts MKB: ARL PDE failure? Upload
No new posts LMM failure? On-Board Diagnostics (OBD)
No new posts AVF: What's wrong with it? Upload
