Golf IV Rear Left Sensor Error Code F222
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Post09-08-2010, 20:11    Subject: Golf IV Rear Left Sensor Error Code F222 Quote
Hello.
Address 46: Comfort System
Label file: None
Control unit part number: 1C0 959 799 B.
Component and/or version: 1C Comfort Device HLO 0003.
Encoding: 00259
Operating number: WSC 01271
Extended information: 1C1959801A 1C Tax control.FS KLO 0004
Extended information: 1C1959802A 1C Tax control.BF KLO 0004
Extended information: 1C0959811A 1C Torque control.HL KLO 0004
Extended information: 1C0959812A 1C Tax.HR KLO 0004
"One error found:"
00930 - Rear left central locking control unit (F222).
27-00 - implausible signal.
"Since today, the rear left door on my Golf is no longer opening with the central locking system. It opens and closes from the inside, and the central locking also works for that. The car recognizes when the door is open/closed, just like it does for locked/unlocked. I suspect a microswitch might be the problem. Where should I start troubleshooting? Could there be a cable issue to the central locking actuator, since all positions seem to be recognized correctly?"
Translated on 06-08-2026, 17:40.
Post09-08-2010, 20:14    Subject: Golf IV Rear Left Sensor Error Code F222 Quote
Okay.
/viewtopic.php?t=14123&highlight=00930+zv
I'll check that out; what happened to the Passat could also happen to a Golf.
Translated on 06-08-2026, 17:43.
No new posts Doku Golf 5, Fahrzeug zieht nach links oder rechts Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J: Rear Clicking Noise - Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J bis 03/99, Fehlfunktion am Deckelschloß hinten Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Rear Left Sensor Error 00930 F222 On-Board Diagnostics (OBD)
No new posts A3 8PA rear left brake dragging Transmission, Chassis, Body & Interior
No new posts Audi A4 B8, rear left brake warm Transmission, Chassis, Body & Interior
No new posts Rear A6-4B Window: Automatic Open Issue? Diesel Engine Technology
