Yesterday, my pet hamster died.
Now, the question for me is whether it will damage the engine if I drive it in limp mode with a faulty needle lift valve until I find a new one. Unfortunately, this isn't just about short distances. I have to drive about 100 km on the highway to the university tonight, and at least another 100 km back home to install the new needle lift valve when it arrives.
It would be great if someone could tell me here whether this is a good idea, or if I should look for another way to get into university.
Sure, no problem. Here's the translation:
If it's related to the NHG (are you sure?), you can operate in a limp-home mode. The injection will then be controlled, with a reduced amount. You'll lose power. I wouldn't recommend driving through the Kassel mountains. For safety, disconnect the connector to the NHG (next to the diesel filter).
@Michael
Naturally controlled, my apologies. Specifically, the injection timing lacks a closed-loop (control) system.
I hope you still confirm my proposal.
I just realized that I didn't thank you for your answers back then! So, here's a heartfelt thank you again. By the way, I took the opportunity to replace the injectors with AFN injectors (it's a 1Z engine), and everything is working again.
Best regards, Kaindl.
