Golf 1J documentation up to 05/99, sunroof stuck (Solution)
Michael II
Post06-03-2003, 15:17    Subject: Golf 1J documentation up to 05/99, sunroof stuck Quote
Sunroof is stuck when opening/closing.
Cause:
The sunscreen slide is coming out of its track. Sliders, detached slider parts, or loose sunscreen can become lodged in the mechanism of the guide frame.
Note: The sliders may come loose, for example:
If the sun protection is installed during the roof lining installation process due to excessive...
The voltage is being pushed upwards.
While peeling off and removing the protective film.
By tilting it to one side when sliding the sunshade into place.
Solution:
When performing maintenance or replacing parts, it is important to ensure that no fragments of the slider remain within the mechanism of the guide frame!
Modified replacement parts, sliders as individual items, or sunshades with sliders, are marked on the packaging with a green dot, with a diameter of 19 mm.
Tschüss
Michael II
Ratings - Golf 1J documentation up to 05/99, sunroof stuck
No new posts Golf 1J: Sunroof Rattle Noise - Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 KJ 2002, Steering lock jammed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo MJ 2002: Stuck A/C or Recirculation Button Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 3 '97: Sunroof Seal Leak? Transmission, Chassis, Body & Interior
No new posts Golf 3 sunroof "clicks" or "makes a clicking noise" Transmission, Chassis, Body & Interior
No new posts DSG Shift Knob Stuck: Troubleshooting & Fixes Transmission, Chassis, Body & Interior
No new posts AFN VTG 96: Stuck Valve - Troubleshooting:( Diesel Engine Technology
