All aggregates 02K.
Switching difficulties, circuit with no function.
Cause:
The selector rod or connecting rod of the external control mechanism has detached.
Excessive wear on the bearing/ball joint coupling components.
Solution:
Spare part.
- Selector lever, part number 1J0 711 596 C.
- Tie rod number 1J0 711 803 B
In the case of a "detached" selector or coupling rod, both the detached part and its corresponding counterpart (console/shift lever/selector lever) must be replaced!
If another selector or coupling rod is attached to the metal "exchange part", then this rod must also be replaced.
Tschüss
Michael II
Translated on 17-10-2026, 16:24.
