Audi 2.5 TDI BDG: Engine Problems & Solutions
bers
Post03-12-2008, 17:53    Subject: Audi 2.5 TDI BDG: Engine Problems & Solutions Quote
Hello, maybe someone here can help me. I'm having a problem with my Audi.
During the drive, I experienced a sudden loss of power. The engine then stopped responding to the accelerator, and the check engine light came on (limp mode).
I have the following errors in the engine control unit:
01282 035 Switching valve for intake manifold control flap - N239.
sporadically
01259 031 Fuel pump relay J-17 - Open circuit/Short to ground.
sporadically
01375 031 Valves for engine mounting, Level 1 - Short circuit to ground/open circuit.
sporadically
...... Valves for engine mounting, Level 1 - Short circuit to ground.
sporadically
17809 P1401 035 Exhaust gas recirculation valves - Short circuit to ground.
sporadically
01262 031 magnetic valve, boost pressure control - N75: Open circuit/Short circuit to ground.
sporadically
The errors reappear all at once after deleting them.
"Does anyone else experience this problem? How do I fix the error? I suspect it's the engine control unit."
Translated on 28-10-2026, 20:02.
mullemaus
Post03-12-2008, 20:29    Subject: Audi 2.5 TDI BDG: Engine Problems & Solutions Quote
Translated on 28-10-2026, 20:04.
bers
Post04-12-2008, 8:14    Subject: Audi 2.5 TDI BDG: Engine Problems & Solutions Quote
Yes, all fuses and connections are fine. There are no visible or measurable faults in the wiring.
bers
Post05-12-2008, 10:51    Subject: Audi 2.5 TDI BDG: Engine Problems & Solutions Quote
Has absolutely no one heard of this error before, or have any idea what it might be?
I found a post in the forum from May of this year describing the same error, but unfortunately, the author hasn't responded to tell me how they fixed it.
Eis_Becher
Post28-01-2010, 20:08    Subject: Audi 2.5 TDI BDG: Engine Problems & Solutions Quote
I'm experiencing the exact same problem. I initially thought it might be due to one of these components, since they all share a common power supply line. I tried isolating the issue by disconnecting each component individually, but all the components seem to be okay. Have you managed to resolve the problem yet?
Translated on 28-10-2026, 20:05.
schrauber2904
Post01-02-2010, 19:24    Subject: Audi 2.5 TDI BDG: Engine Problems & Solutions Quote
Please clean the grounding points. It's a common mistake.
speedy_V6_8E
Post04-08-2010, 15:14    Subject: Audi 2.5 TDI BDG: Engine Problems & Solutions Quote
I've been having the same problem for over three months.
1. The turbocharger boost pressure control valve (N75) was replaced. After 30 km, the errors reappeared.
2. Control unit checked. => Allegedly OK.
3 fuel pump relay J-17 units were replaced. 1000 km of trouble-free operation.
4. Contacts on the control unit connector were replaced. 650 km, all okay.
Have you found the error?
Translated on 28-10-2026, 20:06.
No new posts Audi 1Z LLK: Coolant Replacement Guide Diesel Engine Technology
No new posts ZV audi A8 On-Board Diagnostics (OBD)
No new posts Audi A6: Mass Air Flow Sensor (MAF) Problem? Upload
No new posts logarithm calculation for LMM on Audi A6 Upload
