08-12-2011, 0:16 Subject: V157 Fan & Cooler Repair: Get it Fixed! |
Hi.
I have a G5 BKD "in storage" whose throttle body and radiator fan are supposedly "broken."
Yes, the throttle is no longer making that squeaking noise (which is what my identical one and all the others I know do), and the fan is not running in the actuator diagnostics.
"Also, the engine also stalls during the AGR test... apparently, the throttle is closing so much that without the AGR system, there's no more air getting in."
The AGR valve is new because the membrane (which it still has) was torn.
Is there a sensitive point that an animal might have gnawed on, so that the problem is with a cable and not with the two components themselves?
Wednesday, December 7, 2011, 3:00:26:31600 PM.
VCDS Version: RKS 10.6.5
Data as of: 20110418.
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um drauĂen zu sein."
Vehicle type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56 62 72 77
7D
Vehicle Identification Number: WVWZZZ1KZ4W121XXX
Mileage: 150,360 km
00-Steering angle sensor -- Status: OK 0000
01-Motor -- Status: Error 0010.
02-Gearbox -- Status: OK 0000
03-Brakes -- Status: OK 0000
08-Climate/Heating -- Status: OK 0000
09-On-board network -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-inch steering wheel -- Status: OK 0000
17-in-1 instrument -- Status: OK 0000
19-CAN Gateway -- Status: Error 0010.
Immobilizer -- Status: Intermittent communication error 1000.
37-Navigation -- Status: Error 0010.
42-Door Electric Driver -- Status: Error 0010.
44-Steering Assist -- Status: OK 0000
46-Comfort System -- Status: OK 0000
52-door electric passenger side door - Status: OK 0000.
55-Beam adjustment. -- Status: OK 0000
56-Radio -- Status: OK 0000
62- Door, electric, left and right -- Status: OK 0000
72-Door, electric, high, right side -- Status: Error 0010.
77-Phone -- Status: OK 0000
7D Auxiliary Heater -- Status: OK 0000
Address 01: Engine, Label file: RKS\03G-906-016-BKD.lbl
Part number SW: 03G 906 016 AP, HW: 028 101 167 2.
Component: R4 2.0L EDC G000AG 5876
Revision: 12345678 Serial number: VWZ7Z0D9458952
Coding: 0000078
Operating number: WSC 00000 028 00001
VCID: 71E245861132
3 errors found:
18051 - Please read the error memory of the central electronic system.
P1643 - 000 - -
Environmental conditions:
Speed: 1533 RPM
Torque: 114.0 Nm
Speed: 10.0 km/h
Last: 32.2%
Voltage: 13.98 V
Binary value: 00001000
Last: 57.3%
(no unit): 1.0
19558 - Motor for throttle valve (V157): No signal.
P3102 - 000 - -
Speed: 0 RPM.
Torque: 34.0 Nm
Speed: 0.0 km/h
Last: 0.0%
Voltage: 11.70 V
Binary value: 00001100
Torque: 0.0 Nm
Torque: 92.0 Nm
17075 - Radiator fan control 1: Short circuit to ground.
P0691 - 000 - -
Speed: 819 RPM
Torque: 60.0 Nm
Speed: 0.0 km/h
Last: 0.0%
Voltage: 13.45 V
Binary value: 00001001
Temperature: 50.4°C
Key press ratio: 9.6%
Readiness: 1 1 0 0 0
Address 02: Transmission Label file: RKS\02E-300-0xx.lbl
Part number SW: 02E 300 041 K, HW: 02E 927 770 L.
Component: GSG DSG 0702.
Revision: 02904010 Serial Number: 00000402240175
Encoding: 0000020
Operating number: WSC 01279 785 00200
VCID: 1A30422AAC04
No errors found.
Address 03: Brakes Label file: RKS\1K0-907-379-MK60-F.lbl
Part number: 1K0 907 379 K
Part: ESP FRONT MK60 0103
Encoding: 0023170
VCID: 3A70A2AA0CC4
No errors found.
Address 08: Climate Control/Heating Label file: RKS\1K0-907-044.lbl
Part number: 100 907 044 DX
Part: ClimatronicPQ35 061 0606
Operating Number: WSC 00000 000 00000
VCID: 65CA21D6D5FA
No errors found.
Address 09: Body Control Module
Label file: RKS\3C0-937-049-23-H.lbl
Part number SW: 1K0 937 049 T. Hardware number: 1K0 937 049 T*.
Component: On-board network module 1.0 H30 0704.
Revision: 00030000 Serial Number: 00000000598442
Encoding: E78B8F060004180F001400001400000000
VCID: 4084D0426A18
Part number: 1K1 955 119 B.
Part: VW350 Wiper Blade 012 0401
Encoding: 00065493
Part number: 1K0 955 559 K
Component: RainLightSensor 002 0505
Encoding: 00217125
No errors found.
Address 15: Airbag
Label file: RKS\1K0-909-605.lbl
Part number SW: 1K0 909 605 A, HW: 1K0 909 605 A.
Part number: 0L AIRBAG VW8 022 0500.
Revision: 04022000 Serial number: 0033FD0A9XYY
Coding: 0012364
Operating number: WSC 01268 785 00200
VCID: 2A5092EAFC64
No errors found.
Address 16: Steering wheel
Label file: RKS\1K0-953-549-MY8.lbl
Part number SW: 1K0 953 549 AM, HW: 1K0 953 549 AM.
Component: J0527 032 0070
Coding: 0012142
Operating number: WSC 44261 142 80917
VCID: 7DFA69B65D6A
Part number: XXXXXXXXXXX
Component: E0221 007 0050
No errors found.
Address 17: Combination Instrument
Label file: RKS\1K0-920-xxx-17.lbl
Part number: 1K0 920 870 L
Component: COMBINATION INSTRUMENT VDD 3354
Encoding: 0005101
Operating number: WSC 44261 142 84667
VCID: 32608A8AD4B4
No errors found.
Address 19: CAN Gateway
Label file: RKS\1K0-907-530.lbl
Part number SW: 1K0 907 530 C, HW: 1K0 907 951.
Component: Gateway H08 0080
Revision: 08 Serial Number: 260010430205D7
Encoding: 7F3F0BC8070002
VCID: 27566BDEEF76
"One error found:"
00474 - Control unit for immobilizer system.
004 - No signal/communication - Intermittent.
Error status: 00100100
Error priority: 2
Error frequency: 1.
Lost Count: 45
Time: 0.
Date: 2000.00.00
Time: 12:10:04
Address 25: Immobilizer
Label file: RKS\1K0-920-xxx-25.lbl
Component: IMMO 3354
VCID: 32608A8AD4B4
No errors found.
Address 37: Navigation
Label file: RKS\1T0-919-887.lbl
Part number: 1T0 919 887 B
Component: Navigation 0311
Encoding: 0000002
VCID: 4182D5466112
2 errors found:
02731 - CD reading error.
001 - Upper limit exceeded.
00003 - Control unit.
014 - defective
Address 42: Door electric, driver side
Label file: RKS\1K0-959-701-MIN1.lbl
Part number: 1K0 959 701 E
Component: Door control unit 09 0123.
Coding: 0000052
VCID: 30648082DAB8
"One error found:"
00943 - Driver's side mirror heating (Z4)
012 - Electrical fault in the circuit.
Address 44: Steering Assist
Label file: RKS\1Kx-909-14x-44.clb
Part number: 1K1 909 144 F
Component: EPS_ZFLS, Class 3, Part Number: 1301.
VCID: 2E589EFAC08C
No errors found.
Address 46: Comfort System
Label file: RKS\1K0-959-433-MIN.clb
Part number: 1K0 959 433 C
Component: KSG 0201
Encoding: 00E802087F2D8404084F0100
VCID: 30648082DAB8
No errors found.
Address 52: Door electric, passenger side.
Label file: RKS\1K0-959-702-MIN1.lbl
Part number: 1K0 959 702 E
Component: Door control unit 09 0115.
Coding: 0000052
VCID: 31628586D1B2
No errors found.
Address 55: Headlight range adjustment.
Label file: RKS\1T0-907-357.lbl
Part number: 1T0 907 357.
Component: Dynamic LWR 0002.
Encoding: 0000003
VCID: F4ECCC92EE20
No errors found.
Address 56: Radio
Label file: RKS\1T0-035-095.lbl
Part number: 1T0 035 095.
Component: Radio 0311
Encoding: 0005002
VCID: EBDED7EEB31E
"One error found:"
014 - defective
Address 62: Door electric, left/right.
Label file: RKS\1K0-959-703-GEN1.lbl
Part number: 1K0 959 703 C
Component: Door control unit 06 0202.
Encoding: 0000016
VCID: 30648082DAB8
No errors found.
Address 72: Door electric strike, high, right.
Label file: RKS\1K0-959-704-GEN1.lbl
Part number: 1K0 959 704 C
Encoding: 0000016
VCID: 31628586D1B2
"One error found:"
01037 - Window lifter, thermal protection active; rear right.
000 - - - Sporadically
Address 77: Telephone Label file: RKS\1K0-035-729-UNI.lbl
Part number: 1K0 035 729 B
Component: CIB PAH HW 112 SW 0194
Operating Number: WSC 00001 000 00000
VCID: 285468E2E268
No errors found.
Address 7D: Auxiliary Heater
Label file: RKS\1K0-963-235.lbl
Part number SW: 1K0 963 235 D, Hardware number: 1K0 963 235 D.
Component: PTC element 0404
Revision: 00700000 Serial number:
VCID: 2C5C94F2F690
No errors found.
End. Transparency, Teamwork
Translated on 29-09-2026, 15:37.
Profile PM Garage |
bloesch Profi-Schrauber
Joined: 03/18/2005 Posts: 622 Karma: +16 / -0 Location: FL
08-12-2011, 7:20 Subject: V157 Fan & Cooler Repair: Get it Fixed! |
Quote: | | Is there a sensitive spot that an animal might have gnawed on, so that the problem is with a cable and not with the two components themselves? |
No. But a shared lock  .
Try disconnecting the plug from the throttle valve and then replace the common fuse (I don't have the number handy).
If the fuse remains intact, the throttle valve is likely faulty (which is usually the case).
Translated on 29-09-2026, 16:07.
mullemaus Guest
08-12-2011, 11:28 Subject: V157 Fan & Cooler Repair: Get it Fixed! |
I also have a BKD engine, but it only has this specific issue, without the problem related to the throttle valve.
P0691 - 000 - -
Speed: 819 RPM.
Torque: 60.0 Nm
Speed: 0.0 km/h
Last: 0.0%
Voltage: 13.45 V
Temperature: 50.4°C
Touch ratio: 9.6%
Sure, here's the translation:
'Any ideas?'
Translated on 29-09-2026, 16:09.
08-12-2011, 12:08 Subject: V157 Fan & Cooler Repair: Get it Fixed! |
I'm currently "offline from the good source"...
Can someone help me locate the fuse in the MJ04 G5?
Thank you.
m; Transparency, Teamwork
Translated on 29-09-2026, 16:10.
Profile PM Garage |
haithamina Schrauber
Joined: 05/15/2006 Posts: 666 Karma: +27 / -3 Location: 69221 Dossenheim
08-12-2011, 13:15 Subject: V157 Fan & Cooler Repair: Get it Fixed! |
Hello Martin,
Perhaps this thread, with its reference to S14, might be helpful?
/viewtopic.php?t=24738
haithamina 3G5, 110 kW, DFGA, TGV, Variant HL 2018-
Translated on 29-09-2026, 16:11.
08-12-2011, 13:30 Subject: V157 Fan & Cooler Repair: Get it Fixed! |
SB or SC would already help as a search space restriction  .
Unfortunately, my examination of the Z35 revealed that, despite sharing some identical parts, the models are constructed in completely different ways in other areas.
The relays for the auxiliary heater are located in compartment 1K above the BNSTG, and in compartment 3C in the engine compartment. Transparency, Teamwork
Translated on 29-09-2026, 16:12.
Profile PM Garage |
BM Profi-Schrauber
Joined: 12/07/2005 Posts: 1857 Karma: +8 / -0 Location: NĂ€he DĂŒsseldorf
08-12-2011, 15:16 Subject: V157 Fan & Cooler Repair: Get it Fixed! |
bloesch wrote: | Hello,
Quote: | | Is there a sensitive point that an animal might have gnawed on, so that the problem is with a cable and not with the two components themselves? |
If the fuse remains intact in the future, the throttle valve is likely damaged (which is usually the case). |
I had a similar issue with a different car not long ago. In that case, the fuse was located in the fuse box in the engine compartment. 3B5 AJM
Translated on 29-09-2026, 16:13.
08-12-2011, 17:30 Subject: V157 Fan & Cooler Repair: Get it Fixed! |
I'm entering SB38 into the search system...
Translated on 29-09-2026, 16:14.
Profile PM Garage |
vagtuning Guest
08-12-2011, 22:51 Subject: V157 Fan & Cooler Repair: Get it Fixed! |
I would probably choose SB 8  .
09-12-2011, 0:11 Subject: V157 Fan & Cooler Repair: Get it Fixed! |
Thank you.
I've already realized that the internet led me astray.
That was a picture of a Hi Box, which the TDI doesn't actually have. Transparency, Teamwork
Profile PM Garage |
