blackblizzard Blaumann
01-02-2010, 12:52 Subject: D+ Terminal on Alternator |
Hello!
For what purpose is the D+ terminal actually needed on the alternator? Actually, B+ and B- should be sufficient, the rest is handled by the controller.
Best regards
01-02-2010, 13:01 Subject: D+ Terminal on Alternator |
blackblizzard wrote: | | Actually, B+ and B- should be sufficient, the rest is taken care of by the controller. |
I don't think so.
What is D+?
D+ (Dynamo Plus) = Excitation coil/Charging control light, also Class 61MfG. Michael
Profile PM Garage |
01-02-2010, 13:33 Subject: D+ Terminal on Alternator |
And how does this work with the excitation coil? I have always thought that the controller "manages" this.
01-02-2010, 13:42 Subject: D+ Terminal on Alternator |
blackblizzard wrote: | | And how does this exciter coil work? I have always thought that the controller {controls} |
Yes, he does. However, he needs to know that he should be aiming for something. And that's what he says, how it should be, D+. MfG. Michael
Profile PM Garage |
01-02-2010, 14:16 Subject: D+ Terminal on Alternator |
And how should that work, or how and where is the D+ connected?
Best regards
01-02-2010, 14:42 Subject: D+ Terminal on Alternator |
Please follow the link in this thread:
/viewtopic.php?t=22582&highlight=120a MfG. Michael
Profile PM Garage |
01-02-2010, 15:20 Subject: D+ Terminal on Alternator |
Thank you!
So, man könnte also D+ eigentlich an B+ hängen, dann würde die Lima genau so funktionieren, nur die Ladekontrolleuchte wäre dann ohne Funktion??
Best regards
scroll tdi Blaumann
01-02-2010, 16:09 Subject: D+ Terminal on Alternator |
Your alternator does not have a permanent magnet installed. Therefore, the exciter coil needs a voltage. Without the excitation coil, no electrical energy is generated.
With the bridge, it only works if there is still some residual magnetism in the excitation coil.
01-02-2010, 16:30 Subject: D+ Terminal on Alternator |
I already know that the exciter coil is not a permanent magnet. That's why I'm asking: What if I simply connect the D+ terminal of the alternator to the B+ terminal? Then, current flows through the field coil, and the alternator must also supply power.
01-02-2010, 18:04 Subject: D+ Terminal on Alternator |
Tell me, what your problem is. MfG. Michael
Profile PM Garage |
scroll tdi Blaumann
01-02-2010, 18:11 Subject: D+ Terminal on Alternator |
What came first, the egg or the chicken?
As long as there is no magnetic field, there will be no voltage. Therefore, there will be no voltage for the motor. And therefore, the alternator will not work with the bridge.
01-02-2010, 18:18 Subject: D+ Terminal on Alternator |
I'm only interested in the function of the alternator - specifically, the D+ Kemme.
D+ Depends on the ignition being on, meaning that when the ignition is on, current flows to the excitation coil.
The same effect would also occur if D+ and B+ were connected - however, with a stationary vehicle, the battery would eventually drain.
Is that correct?
AllesScraubermitWerkzeug
01-02-2010, 18:35 Subject: D+ Terminal on Alternator |
Good question...I know exactly what you mean. Yes, the child has only a different name for the purpose of identification.
D+ is connected to the KL.30 (B+). D+ is used solely to identify the wire that supplies the excitation voltage to the alternator.
In principle, Kl.85 on a relay (the copper coil) is simply switched B+ or Kl.15... this is only for easier identification... because everything in a car is B+ or B-, but simply wired differently. Mechaniker ohne eigenes Werkzeug kann nichts werden.
scroll tdi Blaumann
01-02-2010, 19:42 Subject: D+ Terminal on Alternator |
blackblizzard wrote: | My focus is solely on the function of the alternator - specifically on the D+ terminal.
Is that correct? |
must measure whether there is voltage at B+ when the car is stationary.
yes, if that's the case, then the battery will drain...
01-02-2010, 20:38 Subject: D+ Terminal on Alternator |
Thank you, now it's clear
