Brown Stone Chips: Natural & Decorative
Post20-08-2010, 13:47    Subject: Brown Stone Chips: Natural & Decorative Quote
Hi.
I have 3 dents (likely from atmospheric re-entry icon_wink.gif).
Two were located at the front edge of the hood, and one was in the center of the A-pillar.
They have turned brown now.
What should I do?
- Simply seal it with a marker.
- First, "sand" the surface with a fiber optic pen.
I see larger actions, like proper sanding, as overkill.
Translated on 16-10-2026, 3:51.
Post20-08-2010, 14:56    Subject: Brown Stone Chips: Natural & Decorative Quote
1. "Remove rust" using a method that seems appropriate for you (the more thorough the method, the longer the result will last).
2. Apply touch-up paint.
Translated on 16-10-2026, 3:52.
Octavia_4x4
Post23-08-2010, 9:25    Subject: Brown Stone Chips: Natural & Decorative Quote
"I always apply a rust-inhibiting primer first, then some spot putty. I sand it down a bit to make it smooth (using 800 grit sandpaper), and then I use a touch-up pen and clear coat. This way, I can completely smooth out the stone chips and make them almost invisible."
However, it also involves a bit more effort.
Translated on 16-10-2026, 3:53.
Post23-08-2010, 9:28    Subject: Brown Stone Chips: Natural & Decorative Quote
I've now "sealed" them, meaning I've applied paint and a clear coat, and they're finished.
You can always do the loops and have all that fun again.
I'll start by messing around with the golf club icon_smile.gif.
Post23-08-2010, 10:45    Subject: Brown Stone Chips: Natural & Decorative Quote
...can you not remove them from the metal control unit icon_smile.gif...?
Translated on 16-10-2026, 3:54.
Post23-08-2010, 11:18    Subject: Brown Stone Chips: Natural & Decorative Quote
matthiasTDI96 wrote:
...can you not remove them from the metal control unit icon_smile.gif.....
...The basic settings or adjustments would definitely be better there... icon_lol.gif
...which channel was it again for that adjustment??? *hiding*
teileklaus
Avatar-teileklaus
Karma: +12 / -0   Thank you, like it!
2005 Volkswagen
Post23-08-2010, 11:27    Subject: Brown Stone Chips: Natural & Decorative Quote
Sealing the rust first is not a good idea... Why not just use your fiberglass pen to sand it down point by point instead?
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 16-10-2026, 3:55.
